Eeprom corruption
I am having an issue after a reset reading back the data stored by the EDB library. I made a slight modification to the example sketch to show the error I am seeing.
Example Sketch
 EDB_Simple.pde
 Extended Database Library + Internal Arduino EEPROM Demo Sketch
 The Extended Database library project page is here:
#include "WProgram.h"
#include <EDB.h>
// Use the Internal Arduino EEPROM as storage
#include <EEPROM.h>
// Uncomment the line appropriate for your platform
#define TABLE_SIZE 512 // Arduino 168 or greater
// The number of demo records that should be created.  This should be less
// than (TABLE_SIZE - sizeof(EDB_Header)) / sizeof(LogEvent).  If it is higher,
// operations will return EDB_OUT_OF_RANGE for all records outside the usable range.
#define RECORDS_TO_CREATE 10
// Arbitrary record definition for this table.
// This should be modified to reflect your record needs.
struct LogEvent {
  char something[50];
  char something2[8];
  int id;
  int temperature;
logEvent;
// The read and write handlers for using the EEPROM Library
void writer(unsigned long address, byte data)
  EEPROM.write(address, data);
byte reader(unsigned long address)
  return EEPROM.read(address);
// Create an EDB object with the appropriate write and read handlers
EDB db(&writer, &reader);
  Serial.println("Extended Database Library + Arduino Internal EEPROM Demo");
  //db.create(0, TABLE_SIZE, sizeof(logEvent));
  db.open(0);
  Serial.print("Record Count: "); Serial.println(db.count());
  Serial.println("Creating Records...");
  int recno;
  for (recno = 1; recno < RECORDS_TO_CREATE; recno++)
    db.readRec(recno, EDB_REC logEvent);
    Serial.print("ID: "); Serial.println(logEvent.id);
    Serial.print("Temp: "); Serial.println(logEvent.temperature);
    Serial.print("1: "); Serial.println(logEvent.something);
    Serial.print("2: "); Serial.println(logEvent.something2);
  db.clear();
  for (recno = 1; recno <= RECORDS_TO_CREATE; recno++)
    logEvent.id = recno;
    logEvent.temperature = recno * 2;
    strcpy(logEvent.something, "some test data that is long");
    strcpy(logEvent.something2, "test2");
    db.appendRec(EDB_REC logEvent);
Output after upload then pressing reset once.
Record Count: 0
Creating Records...
Record Count: 0
Temp: 0
1:
2:
Temp: 0
1:
2:
Temp: 0
1:
2:
Temp: 0
1:
2:
Temp: 0
1:
2:
Temp: 0
1:
2:
Temp: 0
1:
2:
Temp: 0
1:
2:
Temp: 0
1:
2:
Record Count: 8
Temp: 2
1: some test data that is long
2: test2
Temp: 4
2: test2
Temp: 6
2: test2
Temp: 8
2: test2
Temp: 10
2: test2
Temp: 12
2: test2
Temp: 14
2: test2
Temp: 16
2: test2
Temp: 16
2: test2
Reset button pressed here
Record Count: 8
Creating Records...
Record Count: 8
Temp: 25972
1:
2:
Temp: 25972
1: st2
2:
Temp: 25972
1: st2
2:
Temp: 25972
1: st2
2:
Temp: 25972
1: st2
2:
Temp: 25972
1: st2
2:
Temp: 25972
1: st2
2:
Temp: 25972
1: st2
2:
Temp: 25972
1: st2
2:
Record Count: 8
Temp: 2
2: test2
Temp: 4
2: test2
Temp: 6
2: test2
Temp: 8
2: test2
Temp: 10
2: test2
Temp: 12
2: test2
Temp: 14
2: test2
Temp: 16
2: test2
Temp: 16
2: test2
The first record is numbered 0, not 1. The valid record numbers are 0 to RECORDS_TO_CREATE - 1, not 1 to RECORDS_TO_CREATE.
The size of the LogEvent structure is 50 + 8 + 2 + 2 or more. That is 62 bytes per record, or more. The structure may be padded to for word alignment purposes.
You want 10 records, 62+ bytes each, to fit in a 512 byte table.
Do you think they will really fit?
The first record is 1, this is from the example and i haven't changed the looping logic. in the code it does:
// reads a record from a given recno
EDB_Status EDB::readRec(unsigned long recno, EDB_Rec rec)
  if (recno < 1 || recno > EDB_head.n_recs) return EDB_OUT_OF_RANGE;
  edbRead(EDB_table_ptr + ((recno - 1) * EDB_head.rec_size), rec, EDB_head.rec_size);
  return EDB_OK;
It always does a -1 on the head so you can have a 1 based index.
I am on an at328 with 1k of eeprom space available so there should be plenty of room. I am able to write and read the data properly if i use the EXROM library. I suspect it is a problem with how the EDB library is loading the struct. Below is the EXROM code that i have in my main sketch that is working properly between resets.:
void WriteCharactersToEeprom(int charidx=0) {
  int pos = 0;
  byte len=0;
  byte maxnum = MAX_CHARACTERS;
  if (charidx != 0)
    maxnum = charidx + 1;
  for (int i=charidx;i<maxnum;i++)
    len = 50;
    EXROM.write(pos, characters[i].username, len);
    pos += len;
    len = 8;
    EXROM.write(pos, characters[i].charname, len);
    pos += len;
    len = sizeof(byte);
    EXROM.write(pos, &characters[i].race, len);
    pos += len;
    len = sizeof(byte);
    EXROM.write(pos, &characters[i].room, len);
    pos += len;
    len = sizeof(unsigned int);
    EXROM.write(pos, &characters[i].experience, len);
    pos += len;
I'm just not sure why the EDB isn't working properly between resets.
After shrinking the number of records and table size, I tried running the test on a Teensy++. The board stops responding.
I'm going to go out on a limb and say there's a bug in the EDB library. Eye-balling the source code, I didn't see any problems. My suggestion is to contact the EDB author.
Thanks for the help, I just wanted to make sure I wasn't missing something obvious.
Hopefully, we both didn't miss the obvious. :wink:
This is an old thread by now, but I just wanted to add that I couldn't get this library to work either (after a reset). Instead, I switched back to the more simple library DB and that one works fine.
I'm having problems with the EDB library using an AT24C1024 memory, first I create a db with some data, I read the data back to verify it was written correctly, and it was.
After i reset the arduino, the data from the two first registers of the database are corrupt, just the two first.
I would like to know if someone is having the same problem. I need some advice.
thanks
i'm appending a capture of five strings i saved to the database,
when I save them and read them back from the database they are like this:
T12345 F200 G200 H200 S1
after a reset the same strings read this:
T17 F0 G0 H8 S0
T2 F200 G200 H200 S1
