Hello, intent for my sketch is to retrieve a stored crc value from EEPROM on boot-up and then check it against current crc value. I'm using Christopher Andrews' sketch as a base.
Issue is, when rebooting my Arduino pro mini, the current-state crc always differs from what was 'put' into EEPROM (savedcrc). The read crc data however does match the crc of the previous state crc.
Where am I going wrong?
#include <Arduino.h>
#include <EEPROM.h>
unsigned long CRC2;
struct MyObject {
float field1;
bool field2;
char name[10];
unsigned long CRC;
// Display EEPROM crc
Serial.print("\nCRC32 of EEPROM data: ");
Serial.println(eeprom_crc(), HEX);
// Get crc and display
getEEPROM();
// Check if current crc is the same as that stored in eeprom
if(CRC2 == eeprom_crc()) Serial.println("\nYes");
else Serial.println("\nNo");
// Save updates to eeprom
saveEEPROM();
void getEEPROM() {
float f = 0.00f; //Variable to store data read from EEPROM.
int eeAddress = 0; //EEPROM address to start reading from
eeAddress = sizeof(float); //Move address to the next byte after float 'f'.
MyObject customVar; //Variable to store custom object read from EEPROM.
EEPROM.get(eeAddress, customVar);
Serial.println("\nRead custom object from EEPROM: ");
Serial.println(customVar.field1);
Serial.println(customVar.field2);
Serial.println(customVar.name);
Serial.println(customVar.CRC, HEX);
void saveEEPROM() {
float f = 0.00f; //Variable to store in EEPROM.
int eeAddress = 0; //Location we want the data to be put.
MyObject customVar = {
123.86f,
0,
"TEST 888",
eeprom_crc()
eeAddress += sizeof(float); //Move address to the next byte after float 'f'.
EEPROM.put(eeAddress, customVar);
Serial.print("\nData written: ");
/* Empty loop */
unsigned long eeprom_crc(void) {
const unsigned long crc_table[16] = {
0x00000000, 0x1db71064, 0x3b6e20c8, 0x26d930ac,
0x76dc4190, 0x6b6b51f4, 0x4db26158, 0x5005713c,
0xedb88320, 0xf00f9344, 0xd6d6a3e8, 0xcb61b38c,
0x9b64c2b0, 0x86d3d2d4, 0xa00ae278, 0xbdbdf21c
unsigned long crc = ~0L;
for (int index = 0 ; index < EEPROM.length() ; ++index) {
crc = crc_table[(crc ^ EEPROM[index]) & 0x0f] ^ (crc >> 4);
crc = crc_table[(crc ^ (EEPROM[index] >> 4)) & 0x0f] ^ (crc >> 4);
crc = ~crc;
return crc;
