i want to move eeprom data's to buffer and then displaying the data via Serial.print or lcd .print . currently code doing Serial.print inside the loop but i want copy the data to buffer like char with pointer . can anyone suggest the code's to move the data from eeprom to buffer memory .
#include <Wire.h>
char somedata[] = "GREAT"; // data to write
char somedata1[] = "good"; // data to write
char somedata2[] = "okok";
uint16_t intValue = 105;
uint8_t d = 255;
char somedata3[] = "1235.25689";
void i2c_eeprom_write_byte( int deviceaddress, unsigned int eeaddress, byte data ) {
int rdata = data;
Wire.beginTransmission(deviceaddress);
Wire.write((int)(eeaddress >> 8)); // MSB
Wire.write((int)(eeaddress & 0xFF)); // LSB
Wire.write(rdata);
Wire.endTransmission();
delay(10);
// WARNING: address is a page address, 6-bit end will wrap around
// also, data can be maximum of about 30 bytes, because the Wire library has a buffer of 32 bytes
void i2c_eeprom_write_page( int deviceaddress, unsigned int eeaddresspage, byte* data, byte length ) {
Wire.write((int)(eeaddresspage >> 8)); // MSB
Wire.write((int)(eeaddresspage & 0xFF)); // LSB
byte c;
for ( c = 0; c < length; c++)
Wire.write(data[c]);
delay(10);
byte i2c_eeprom_read_byte( int deviceaddress, unsigned int eeaddress ) {
byte rdata = 0xFF;
Wire.requestFrom(deviceaddress,1);
if (Wire.available()) rdata = Wire.read();
return rdata;
Wire.begin(); // initialise the connection
i2c_eeprom_write_page(0x50, 0, (byte *)somedata, sizeof(somedata)); // write to EEPROM
i2c_eeprom_write_page(0x50, 64, (byte *)somedata1, sizeof(somedata1));
i2c_eeprom_write_page(0x50, 128, (byte *)somedata2, sizeof(somedata2));
i2c_eeprom_write_byte(0x50, 192, d);
i2c_eeprom_write_byte(0x50, 256, lowByte(intValue));
i2c_eeprom_write_byte(0x50, 257, highByte(intValue)) ;
//i2c_eeprom_write_page(0x50, 60, (byte *)somedata3, sizeof(somedata3));
Serial.println("Memory written");
int addr=0; //first address
byte b = i2c_eeprom_read_byte(0x50, 0); // access the first address from the memory
while (b!=0)
Serial.print((char)b); //print content to serial port
addr++; //increase address
b = i2c_eeprom_read_byte(0x50, addr); //access an address from the memory
Serial.println(" ");
int addr1=64;
byte e = i2c_eeprom_read_byte(0x50, 64); // access the first address from the memory
while (e!=0)
Serial.print((char)e); //print content to serial port
addr1++; //increase address
e = i2c_eeprom_read_byte(0x50, addr1); //access an address from the memory
int addr2= 128;
byte f = i2c_eeprom_read_byte(0x50, 128); // access the first address from the memory
while (f!=0)
Serial.print((char)f); //print content to serial port
addr2++; //increase address
f = i2c_eeprom_read_byte(0x50, addr2); //access an address from the memory
byte g;
int addr3 = 192;
g = i2c_eeprom_read_byte(0x50, addr3);
Serial.print(g);
byte l = i2c_eeprom_read_byte(0x50, 256);
byte h = i2c_eeprom_read_byte(0x50, 257);
int combineInt = word(h,l);
Serial.print(combineInt);
/*int addr5= 60;
byte z = i2c_eeprom_read_byte(0x50, 60); // access the first address from the memory
while (z!=0)
Serial.print((char)z);//print content to serial port
addr5++; //increase address
z = i2c_eeprom_read_byte(0x50, addr5); //access an address from the memory
delay(2000);
