I would like to store some product data in the EEPROM, so this can survive over restart and reset as well as firmware upgrade.
I have a schema that stores the data in EEPROM, then dumps the EEPROM content on the Serial line. The dump looks OK. So I believe that the EEPROM.write is working as it should.
Then I load another schema that reads the content and this is all zeroed. Like if I was using RAM
Reference Arduino MEGA2560
Arduino IDE 1.6.7 on Windows 10.
This me again. As the error looks really strange I made the same sketch running on a Uno and this is working as expected => perfectly. So, this not my code, but rather something wrong either in the HW (but I don't have another Mega for the test) or in the base libraries.
Here is the code for your review. The exact same code on Uno works perfectly. There are additional traces as I had some doubt about everything.
char* partnumber="AQS-G6P4W3-V12";
char* serialnumber="XZ182400001";
byte mac[] = {
 0xCA, 0xEE, 0xBB, 0xC0, 0x00, 0x01
void write_part() {
 unsigned int i;
 Serial.print("Part number:");
 Serial.println(partnumber);
 for(i=0;i<strlen(partnumber);i++){
  int v = partnumber[i];
  Serial.print(i);
  Serial.print(" V=");
  Serial.println(v);
  EEPROM.write(i,v);
void write_serial(){
 unsigned int i;
 unsigned int base=16;
 Serial.print("Serial number:");
 Serial.println(serialnumber);
 for (i=0;i<strlen(serialnumber);i++)
  EEPROM.write(base+i,serialnumber[i]);
void write_mac() {
 unsigned int i;
 unsigned int base=32;
 Serial.println("Mac address:");
 for(i=0;i<6;i++){
  EEPROM.write(base+i,mac[i]);
Ok, I will post more code, but this code is working fine until I put the same code in another sketch.
Note, that the same code is running on Uno without problem.
void e2reader(int dump_size){
 char buffer[16];
 char valuePrint[4];
 byte value;
 unsigned int address;
 uint8_t trailingSpace = 2;
 Serial.print("Dumping "); Serial.print(dump_size + 1);
 Serial.println(" bytes from EEPROM.");
 Serial.print("baseAddr ");
 for(int x = 0; x < 2; x++){
  Serial.print(" ");
  for(int y = 0; y < 25; y++)
   Serial.print("=");
 // E2END is a macro defined as the last EEPROM address
 // (1023 for ATMEGA328P)
 for(address = 0; address <= dump_size; address++){
  // read a byte from the current address of the EEPROM
  value = EEPROM.read(address);
  // add space between two sets of 8 bytes
  if(address % 8 == 0)
   Serial.print(" ");
  // newline and address for every 16 bytes
  if(address % 16 == 0){
   //print the buffer
   if(address > 0 && address % 16 == 0)
    printASCII(buffer);
   sprintf(buffer, "\n 0x%05X: ", address);
   Serial.print(buffer);
   //clear the buffer for the next data block
   memset (buffer, 32, 16);
  // save the value in temporary storage
  buffer[address%16] = value;
  // print the formatted value
  sprintf(valuePrint, " %02X", value);
  Serial.print(valuePrint);
 if(address % 16 > 0){
  if(address % 16 < 9)
   trailingSpace += 2;
  trailingSpace += (16 - address % 16) * 3;
 for(int i = trailingSpace; i > 0; i--)
  Serial.print(" ");
 //last line of data and a new line
 printASCII(buffer);
Here is the result I have just after the write. I can power off the card and reset, this is still the same results
If I load another sketch that is doing only the reading, then this is all zero.
How are you loading the new sketch?
Are you loading the new sketch through the normal usb/serial interface with a bootloader on the processor, or are you loading using icsp.
There are fuse settings controlling eeprom behavior when using icsp, but the fuse settings don't effect the eeprom behavior when a sketch loaded "normally" through usb with the bootloader.
