I’m trying to compile the following short blurb of code in a library, but it’s giving me the following error (… for omissions):
...\EEPROM.cpp: In function 'unsigned char memByteEEPROM(const void*)':
...\EEPROM.cpp:14:51: error: 'EEPROM' was not declared in this scope
unsigned char memByteEEPROM(const void* x){return EEPROM.read(x);}
I feel like I’m missing something obvious, especially because I’m new to cpp. It worked fine when my library was one file, but now that I tried to split it into different headers and cpp files, this EEPROM error is coming up.
The relevant code in EEPROM.cpp is below:
#include <EEPROM.h>
#include <Arduino.h>
/* return EEPROM byte at address x */
Relevant portions of the headers and linked headers are also below.
I’m compiling on win10 in the arduino IDE, 1.8.5 for the Arduino Uno. Any help is appreciated! I have tried removing the “#include <EEPROM.h>” from dump.h or EEPROM.h so I don’t think double including the EEPROM has anything to do with it?
Hmm... seems you're right on that one, I am now casting the void * to a uint8_t now. However, I'm still getting the same error as before, and compilation stops before before it even gets to the point where it would have an issue with a void * not being uint8_t. Also tried changing the parameter itself to a uint8_t, but the compiler's still hitting the EEPROM error above and exiting straight away.
Wait timeout, I think I just realized what’s happening… I’m pretty sure because I have a file header named as EEPROM.h in my library that its clashing with the library EEPROM, so the namespace is getting screwed up and hence I’m not getting access to EEPROM libraries. I will try changing the names of my files and see if it fixes the error.
Thanks @all for your suggestions, I changed my header file name away from "EEPROM.h" and everything worked. That was quite a silly mistake from me. I believe namespace conflicts indeed were the problem.
