EEPROM help please. 0 to 10,000 and anywhere in between.
I am creating a lighting controller for a remote control car.
I have the code working, while the Arduino is running, but the way it works right now, it needs to be calibrated every time you want to use it.
I would like to store data created by calibration into EEPROM, and call the data from there during boot,. unless a button is pressed. Pressing a button, should start the calibration routine, after the first boot. During the first boot, I would like to go right into the setup routine --sort of a new device initialization.
The issue I have, is that I found that these values can range anywhere from 0 to 10,000, and from what I can see, EEPROM values can only go from 0 - 255.
Would someone please assist me with my EEPROM programming? I have never done anything like this before, and just bought my first Arduino --the nano, and started my first program only a few days ago.
For setup calibration checking, I was thinking about running through setup, and after it is done, write something into EEPROM, that could be checked with an if statement that checks for that value, or if a button is pressed while the setup loop is running --5 seconds.
I will be adding 2 more channels in the future, throttle, and 3rd channel.
The variables that need values stored, are
SteerOnBelow
SteerMin
SteerOnAbove
SteerMax
Any of these variables, can range from 0 to 10,000.
// constants won't change. Used here to
// set pin numbers:
const int led = 13; //Internal LED
const int steer_read = 2; //Steering read
const int throt_read = 3; //Throttle read
const int aux_read = 4; //Aux Channel read
const int left_ts = 5; //Left turn signal
const int right_ts = 6; //Right turn signal
const int break_lt = 7; //Brake Light
const int backup_lt = 8; //Backup Light
// Variables will change:
int ledState_leftts = LOW;             // ledState used to set the left ts
int ledState_rightts = LOW;             // ledState used to set the right ts
long previousMillis = 0;        // will store last time LED was updated
//CalibrationVariables
//Steer Cal
int SteerValue = 0;         // the steer sensor value
int SteerMin = 10000;        // minimum steer sensor value
int SteerMax = 0;           // maximum steer sensor value
int SteerOnBelow = 0;
int SteerOnAbove = 0;
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long interval_for_flashers = 667;           // interval_for_flashers at which to blink (milliseconds)
 Serial.println("Hello world!");
 pinMode(led, OUTPUT);
 pinMode(steer_read, INPUT); //Steering read
 pinMode(throt_read, INPUT); //Throttle read
 pinMode(aux_read,INPUT); //Aux 3 read
 pinMode(left_ts,OUTPUT);//Left Turn Signal
 pinMode(right_ts,OUTPUT);//Right Turn Signal
 pinMode (break_lt, OUTPUT);//Brake light
 pinMode (backup_lt, OUTPUT);//Backup light
//CALIBRATION ROUTINE
  // calibrate during the first five seconds
   while (millis() < 5000) {
  // turn on LED to signal the start of the calibration period:
   digitalWrite(led, HIGH);
//assign inputs to read
     int SteerValue = pulseIn(steer_read, HIGH);
     // record the maximum steer sensor value
   if (SteerValue > SteerMax) {SteerMax = SteerValue;}
    SteerOnAbove = (SteerMax - 200);
  // record the minimum steer sensor value
   if (SteerValue < SteerMin) { SteerMin = SteerValue;}
    SteerOnBelow = (SteerMin + 200);
   // signal the end of the calibration period
   digitalWrite(13, LOW);
int strduration = pulseIn(steer_read, HIGH);
if (strduration <= SteerOnBelow || strduration >= SteerOnAbove){
  if (strduration <= SteerOnBelow){
    //Turn Left
  if(currentMillis - previousMillis > interval_for_flashers) {
     // save the last time you blinked the LED
     // if the LED is off turn it on and vice-versa:
     if (ledState_leftts == LOW)
       ledState_leftts = HIGH;
     // set the LED with the ledState of the variable:
     digitalWrite(led, ledState_leftts);
     digitalWrite(left_ts, ledState_leftts);
 }//close if below
if (strduration >= SteerOnAbove){
  //Turn Right
     if (ledState_rightts == LOW)
       ledState_rightts = HIGH;
     digitalWrite(led, ledState_rightts);
     digitalWrite(right_ts, ledState_rightts);
//clost if > above
else {
  digitalWrite (left_ts, LOW);
  digitalWrite (right_ts, LOW);
  digitalWrite (led, LOW);
//close the loop
Serial.println(SteerOnBelow);
Serial.println(SteerMin);
Serial.println(SteerOnAbove);
Serial.println(SteerMax);
Where is your code that attempts to store the values in EEPROM? What is the problem with that code?
Any you can't figure out how to get the highByte() and lowByte() from the int?
No, honestly, I do no not. The section in the reference is overly breif.
Thank you for letting me know there is a way to do it.
Would someone please explain how to write/read low byte/high byte to/from the EEPROM, and recombine them to make the int to assign to the variable?
There are four parts to what you want to do.
First is int -> bytes. The highByte() and lowByte() functions handle that.
Second is writing the bytes to EEPROM. EEPROM.write() manages that.
Third is reading the bytes from EEPROM. EEPROM.read() takes care of that.
Fourth is reconstructing the int from the bytes. word() does that part.
All of the functions are documented on the reference page(s).
Try something. If it doesn't work, post what you tried, and we'll help.
I think I am getting there, however, I came across another question.
Do I have to somehow convert from decimal to binary, and back again, or will highByte, lowByte, and word take care of this conversion?
I believe, the if comarisons are made a decimal vale--strduration.
mids1999:
Decimal, binary, hex, octal, etc., are just text representations of a piece if data; it's all the same to the microcontroller.
The data is stored in binary. Any conversion to other bases is for display purposes only.
You could post your code for a sanity check. The only thing we don't do is write it for you.
Can't argue with that.
Sorry,
Legally blind, and typed that on a phone.
