Hello,
I am writing 22bytes of data to eeprom
for this i define a starting adress (in this case 0x40), then i use a for loop to write data. After writing, i check the data:
This is what my checking system delivers:
//read eprom before write
EEPROM: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
// print data out to serial
DATA: 00 1C 00 28 28 00 00 03 E7 50 1B 00 00 01 01 01 02 01 03 E7 FF FF
//write and then read data of eeprom
EEPROM: 00 1C 00 28 28 00 00 03 E7 50 1B 00 00 01 01 01 02 01 03 E7 FF FF
for further programming steps, i want to acces specific bytes on the eprom with single "EEPROM write"
for example the 10th byte of the 22bytes
uint8_t value = EEPROM.read(0x50); //0x40 start + 10bytes = 0x50
in the correct case i should see:
serial.println(value,HEX);
printing "1B"
but instead i get a "2".
If i accces adress 49 i get correct "50".
So there isnt a general error here.
My thoughts where that maybe the eeprom has a defective sector, so it tried many starting adresses, but i always get the same issue?
What could be the problem?
