EEPROM LED program
the LED program
then I made this program that will compare the EEPROM value to num.4 and compares the F variable to num.4 known that both F and the EEPROM values are 4. and then I changed both of the values to 3. shouldn't the GREEN LED of the EEPROM still on because it has already stored num.4??
#include<EEPROM.h>
  pinMode(12,OUTPUT);
   pinMode(11,OUTPUT);
EEPROM.write(0,4);                 //GREEN LED
    int f=4;                        //RED LED
  if(EEPROM.read(0)==4)
    digitalWrite(12,HIGH);
  if(f==4)
        digitalWrite(11,HIGH);
When the EEPROM contains 3 and it is compared with 4, then they are not the same.
We would like to see a sketch that shows the problem, but you show the sketch that does not have a problem.
I think this is easier to test with the serial monitor.
#include<EEPROM.h>
const int greenLedPin = 12;
const int redLedPin = 11;
  Serial.begin( 9600);
  Serial.println( "-------------------------------------------");
  pinMode( greenLedPin, OUTPUT);
  pinMode( redLedPin, OUTPUT);
  // Show what was previously stored in EEPROM
  byte value0 = EEPROM.read( 0);
  byte value1 = EEPROM.read( 1);
  Serial.print( "EEPROM location 0 : ");
  Serial.print( value0);
  if( value0 == 4)
    Serial.print( "  (it is equal to 4)");
    Serial.print( "  (it is not equal to 4)");
  Serial.print( "EEPROM location 1 : ");
  Serial.print( value1);
  if( value1 == 100)
    Serial.print( "  (it is equal to 100)");
    Serial.print( "  (it is not equal to 100)");
  // Store a new number in location 0 and 1 of the EEPROM
  // The randomSeed() is used to make a different random number after restarting.
  randomSeed( word( value0, value1) + analogRead( A0) + analogRead( A1));
  byte newValue0 = 3 + (byte) random( 0, 3);
  byte newValue1 = 98 + (byte) random( 0, 5);
  EEPROM.write( 0, newValue0);
  EEPROM.write( 1, newValue1);
  Serial.print( "New values have been written (");
  Serial.print( newValue0);
  Serial.print( " and ");
  Serial.print( newValue1);
  Serial.println( ")");
  Serial.println( "Press reset or disconnect power and see what happens next time");
