I was looking for confirmation that the .write method effectively used the .update method, as I'm sure I read it somewhere....
Then again, I'm using .get and .put, because all of my EEPROM data is in one structure.
Furthermore, I read the docs on Robust_EEPROM, and it did not mention how .writes are performed either.
Having said all of that, on this project I'm using an ESP8266 (Wemos Mini), and could possibly migrate it to ESP8266_EEPROM, although the effort to do that is not minor. A simple EEPROM.commit after a EEPROM.put is no deal-breaker.
Someone in the know needs to do a comprehensive article on the different EEPROM libraries available across as many platforms as possible (or perhaps one exists and I've just not found it)
On an ESP8266 the library works from a buffer that is committed to flash when you say so. The write() method does check if the byte is different to set the dirty flag (that would trigger an actual flash sector erase and dump upon commit)
Just make an array, fill it with whatever needs be saved, and put the whole thing in one pass, when you get it later extract from array, and you neednt worry about where to place what, might be a tad slower depending of how much data you want to save then adressing individually but way easier.
If the parts of the array change then only those parts should wear eeprom since other data remains the same, not entirely sure about that tho
And you can reed eeprom at the start, and use the array for reference later without reading eeprom
OP’s approach is way more flexible as it supports different types
On AVR only the bytes that need changing would be actually written. For the ESP and thus flash, it’s a sector transaction so one dirty bit requires a full sector write. (That’s why you commit the buffer and not a single variable)
would be good to know what he wants to save... I used eeprom to save some pid tunings and frequencies, so array was perfect on uno, if its alot of different data, you re right
If you have different conceptual values being stored, a struct leads to more readable code than a 2D array and you get to choose the best type for each value
they were double and int, so array was double... worked like a charm for the little bit of data, struct seems even better
I had a few interrupts so I wanted to avoid coruption when saving
So when you fetch the data in memory in the setup to fill the struct, if the sentinel
Is not the known keyword (0xDEADBEEF or similar hexspeak values are usually found there) then you know it’s the first time the eeprom was being used and you can initialize it with defaults values
Also I would not disable interrupts to write to eeprom, I would make sure to use a copy of the data (simpler to assign a struct to another one or call a function and pass by value versus making an explicit copy of an array ) so that if the values are being used in an interrupt they would not be affected by the eeprom operation
+1 for my programming skill right there
structured variables, very nice indeed, also genious sentinel
I needed to rewrite after saving the first time XD
