EEPROM library
Hi, I suspect that it I call EEPROM.write(addr) and addr is a number larger than the memory size, the higher order bits are just discarded. Is it so? Do you think it would it be nice to have a MAXEEPROMADDR constant defined as the last valid address, that would change depending on the board, so that I can write a code that runs on different arduinos, for instance the different versions of the NANO ? Otherwise a small data logger, for instance, would destroy previously stored values. What do you think ?
frikosal: I suspect that it I call EEPROM.write(addr) and addr is a number larger than the memory size, the higher order bits are just discarded. Is it so?
Yes.
Put this at the top of your Sketch and you'll be good to go...
define MAXEEPROMADDR E2END
Or, you can just use E2END.
Just tried, it works. Thanks ! Is that E2END constand described somewhere in the reference ?
http://www.nongnu.org/avr-libc/user-manual/group__avr__io.html
