ABSTRACT:
A convention to make EEPROM and perhaps other memory management easier at low cost.
BACKGROUND:
Arduino devices provide a small amount of on-board EEPROM memory. This can be quite useful to store infrequently changed information, such as a calibration table for a touch screen or identification information.
However, the standard EEPROM library only provides read and write access for absolute addresses. This is fine if only a single library is used in a project. Multiple libraries may attempt to use the same addresses and interfere. Managing multiple libraries requires modification of the libraries or mutual awareness of the libraries, which is suboptimal.
What is needed is a mechanism by which multiple libraries can use an EEPROM space without modification and the need to be mutually aware.
At the same time, the EEPROM is limited (1K on the Arduino Uno), so fancy storage mechanisms such as resource forks would be costly.
PROPOSAL:
That a convention be adopted for EEPROM and possible other memory management, as follows:
- That memory be allocated as a series of contiguous blocks, starting at address 0 as per the EEPROM library.
- That the first 1 byte (or more) of each block shall be a UTF-8 encoded number giving the length of the block in bytes, excluding the UTF-8 length.
- That the sequence of blocks be terminated by a single null byte.
RATIONALE:
A block with fewer than 128 bytes only requires a single byte to determine the length, which isn't much. No block on the standard Arduino Uno EEPROM will require more than two extra bytes. The Arduino has a lot more power than memory, so a linear search isn't bad. Sketches that consume blocks can recognize the blocks they need by length and content and can easily skip over blocks they do not need.
If there is something that does the same thing, even if differently, I'll be happy to use it. If not, I'd like to see if we can get agreement and come up with a standard. I'm willing to write a library for this, which should be easy, and let Arduino promulgate it.
If not, I'll do it anyway, because I need it for two libraries I have written, which may or may not be used together.
If there is a more appropriate forum for this, please feel free to move it. I was unable to find a better one.
