Hello friends, I want to save the temperature setting I set with EEProm in the code below, can you help me?
#include
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(9, 8, 7, 6, 5, 4);
const int LED_RED=10; //Red LED
const int LED_GREEN=11; //Green LED
const int RELAY=12; //Lock Relay or motor
//Key connections with arduino
const int up_key=3;
const int down_key=2;
int SetPoint=30;
// SETUP
void setup(){
pinMode(LED_RED,OUTPUT);
pinMode(LED_GREEN,OUTPUT);
pinMode(RELAY,OUTPUT);
pinMode(up_key,INPUT);
pinMode(down_key,INPUT);
//Pull up for setpoint keys
digitalWrite(up_key,HIGH);
digitalWrite(down_key,HIGH);
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print("EL Tronic");
lcd.setCursor(0,1); //Move coursor to second Line
lcd.print("Temp. Controller");
digitalWrite(LED_GREEN,HIGH); //Green LED Off
digitalWrite(LED_RED,LOW); //Red LED On
digitalWrite(RELAY,LOW); //Turn off Relay
delay(2000);
// LOOP
void loop(){
double Temperature = ((5.0/1024.0) * analogRead(A0)) * 100; //10mV per degree 0.01V/C. Scalling
lcd.setCursor(0,0);
lcd.print("Temperature:"); //Do not display entered keys
lcd.print(Temperature);
//Get user input for setpoints
if(digitalRead(down_key)==LOW)
if(SetPoint>0)
SetPoint--;
if(digitalRead(up_key)==LOW)
if(SetPoint<150)
SetPoint++;
//Display Set point on LCD
lcd.setCursor(0,1);
lcd.print("Set Point:");
lcd.print(SetPoint);
lcd.print("C ");
//Check Temperature is in limit
if(Temperature > SetPoint)
digitalWrite(RELAY,LOW); //Turn off heater
digitalWrite(LED_GREEN,HIGH); //Turn on Green LED
digitalWrite(RELAY,HIGH); //Turn on heater
digitalWrite(LED_GREEN,LOW);
digitalWrite(LED_RED,HIGH); //Turn on RED LED
delay(100); //Update at every 100mSeconds
