Good morning, I have been wanting to perform a series of functions with the EEPROM for several days, which are to save an SSID and a Password for a Wi-Fi site. These are saved correctly and also read correctly after doing this, but once you rerun, it cannot read what we have previously saved. I've read other questions from people who have similar things, but I can't see what I'm doing wrong. I am attaching my code to see if someone can help me.
When I try to execute the code again after saving, it executes the function to check EEPROm and it tells me that it is empty
Thanks a lot
#include <EEPROM.h>
#include <ESP8266WiFi.h>
#include <ThingsBoard.h>
#include <PubSubClient.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
// SCL GPIO5
// SDA GPIO4
#define OLED_RESET 0 // GPIO0
Adafruit_SSD1306 display(OLED_RESET);
#define WIFI_AP "PRUEBA"
#define WIFI_PASSWORD "1232"
#define TOKEN "#"
// SENSOR
#define PINLED A0
#define Push D0 //
byte Push_lee = 0;
String array_wifi[5] = {"Prueba", "PRUEBA"};
String array_pass[5] = {"1234", "1232"};
String array_eepromssid[5];
String array_eeprompass[5];
WiFiClient wifiClient;
PubSubClient client(wifiClient);
ThingsBoard tb(wifiClient);
char thingsboardServer[] = "##";
int status = WL_IDLE_STATUS;
unsigned long lastSend;
boolean WifiActivado = false;
int intentos = 0;
int aux = 0;
pinMode(PINLED, INPUT);
pinMode(Push, INPUT); //
EEPROM.begin(1024); //64 / 64
String ssid2=readEEPROMdata(0);
String pw2=readEEPROMdata(64);
Serial.println("He almacenado " + ssid2);
Serial.println("Cuya contraseña es " + pw2);
delay(10);
comprobarDataEEPROM();
lastSend = 0;
if ( !tb.connected() ) {
if ( millis() - lastSend > 9000 ) {
sendAnalogData();
lastSend = millis();
tb.loop();
void Wifi() {
String ssid3=readEEPROMdata(0);
String pw3=readEEPROMdata(64);
Serial.println("He almacenado3 " + ssid3);
Serial.println("Cuya contraseña3 es " + pw3);
int n = 0;
int n2 = 0;
int i;
boolean WiFiActivado2 = false;
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
display.clearDisplay();
display.setTextSize(1);
display.setTextColor(WHITE);
display.setCursor(0, 0);
display.println("Buscando puntos de acceso...");
display.display();
n = 0;
intentos = 0;
while ((WiFi.status() != WL_CONNECTED) && (WiFiActivado2 == false)) {
if (intentos > 0) {
n++;
intentos = 0;
Serial.println("CAMBIO DE WIFI!");
WiFi.begin(array_wifi[n], array_pass[n]);
delay(20000);
Serial.println("Connecting " + array_wifi[n]);
Serial.println("Usando la contraseña " + array_pass[n]);
Serial.println(intentos);
//display.clearDisplay();
display.println("Connecting " + array_wifi[n]);
display.display();
intentos++;
if (WiFi.status() == WL_CONNECTED) {
// char test[] = "hello world"; char *strptr = &test[6]; EEPROM_writeAnything(0, strptr);
// EEPROM.write(item, item2 );
Serial.println("ESTOY CONECTADO a: " + array_wifi[n]);
display.display();
Serial.println("Conectado a " + array_wifi[n]);
display.println("Connected! " + array_wifi[n]);
display.display();
WiFiActivado2 = true;
String ssid=readEEPROMdata(0);
String pw=readEEPROMdata(64);
//Serial.println("El punto wifi almacenado era " + ssid);
//Serial.println("La contraseña almacenada era " + pw);
if(ssid.length() == 0){
saveDataToEeprom(array_wifi[n], array_pass[n]);
Serial.println("El punto wifi correcto es " + readEEPROMdata(0));
Serial.println("La contraseña correcta es " + readEEPROMdata(64));
if (WiFiActivado2 == true) {
while (!tb.connected()) {
Serial.println("Conectandose a thingsboard ...");
if ( tb.connect(thingsboardServer, TOKEN) ) {
Serial.println( "[CONECTADO A THINGSBOARD]" );
Serial.print( "[FALLO]" );
Serial.println( " : [Se intentará de nuevo en 5 segundos]" );
// Wait 5 seconds before retrying
delay( 5000 );
void sendAnalogData() {
Serial.println(analogRead(PINLED));
Push_lee = digitalRead(Push);
int a = random(100);
int b = random(100);
tb.sendTelemetryFloat("TemperaturaAleatoria", a);
tb.sendTelemetryFloat("HumedadAleatoria", b);
tb.sendTelemetryFloat("Puerta", Push_lee);
void comprobarDataEEPROM(){
if (array_eepromssid[0].length() == 0){
Serial.println("He comprobado la EEPROM y está vacía");
Wifi();
}else{
Serial.println("Los datos que posee la EEPROM son");
Serial.println(array_eepromssid[0]);
Serial.println(array_eepromssid[1]);
void saveDataToEeprom(String ssid, String pass)
Serial.println("Saving to Eeprom");
if (ssid.length() > 0 && pass.length() > 0) {
//for (int i = 0; i < 128; ++i) {
//EEPROM.write(i, 0);
int index=0;
while(ssid[index]){
EEPROM.write(index, ssid[index]);
Serial.println(ssid[index]);
index++;
//Serial.println("Antes del commit");
//Serial.println(readEEPROMdata(0));
index=0;
while(pass[index]){
EEPROM.write(index+64, pass[index]);
Serial.println(pass[index]);
index++;
//Serial.println("AAAAAA " + ssid);
//Serial.println("AAAAAA " + pass);
EEPROM.commit();
Serial.println("Despues del commit");
array_eepromssid[0] = readEEPROMdata(0);
array_eepromssid[1] = readEEPROMdata(64);
Serial.println(array_eepromssid[0].length());
//EEPROM.end();
//ESP.reset();
Serial.println("Ya he guardado todo");
void erase_eeprom(){
// write a 0 to all 512 bytes of the EEPROM
for (int i = 0; i < 1024; i++) {
EEPROM.write(i, 0);
EEPROM.end();
String readEEPROMdata(int index)
String aux = "";
char caracter;
while(caracter=EEPROM.read(index)){
aux += caracter;
index++;
Serial.println(aux);
return aux;
