EEPROM.put() and EEPROM.get() not working as I expected
The aim of the code is to create a toggle switch (ON/OFF) that does something in each toggle (ON/OFF). I want to store the value of the toggle in the EEPROM memory just in case the power goes off or whatever. Chip: ATtiny85 programmed with Arduino Uno as ISP. Here is my code so far.
My setup:
#include <EEPROM.h>
const int sleeppin= 1;        //connected to an LED
const int buttonpin =  3;   //button pin
int address = 0;               //toggle switch memory address
boolean buttonstate;   // variable for reading the pushbutton status
boolean curtainstate = LOW;  //as of now I set it to low to begin with
  pinMode(buttonpin, INPUT);
  pinMode(sleeppin, OUTPUT);
and here is the actual code:
 buttonstate = digitalRead(buttonpin);      //read button
 EEPROM.get(address, curtainstate);        //read previous state
     if (buttonstate == curtainstate) {       //if the button and state match
      digitalWrite(sleeppin, HIGH);             //turn on LED
     else {                                                //if they dont match
      digitalWrite(sleeppin, LOW);               //turn LED off
      dosomething(curtainstate);                //Do something that depends on the curtain state
      EEPROM.put(address, !curtainstate);   //rewrite the with the new state
where the dosomething() function is defined as
int dosomething(boolean io){
if (io == LOW){
   //DOES, SAY, A
 if (io == HIGH){
  //DOES, SAY, B
The output of the code is A exclusively all the time regardless of pressing the button or disconnecting and connecting the power.
My guess: Im using EEPROM.get() and EEPROM.put() sintax incorrectly.
Thanks in advance!
How do you have your button pin wired?
When you're having problems with a sketch. It's a good idea to add some Serial.println() statements and then run the sketch with Serial Monitor open so you can understand what's happening. In this case, having a Serial.println() of buttonstate after the digitalRead() and curtainstate after the EEPROM.get() would likely be extremely helpful. You might find that the EEPROM code is working fine, but it's the digitalRead() that's not giving the result you expect.
