EEPROM Questions
Hi all,
I'm curious on possibly making a fail safe function in my code to basically backup a variable to two locations of EEPROM and also recognizing if the first one goes bad to switch to the second. Obviously EEPROM has quite a life to it (100,000 reads and writes with extended life using EEPROM.update).
I guess my main question would be does the following make sense?
if (!EEPROM.read(x)){
//do stuff
No. Comparing to a specific value would, but that test does not.
EEPROM has a guaranteed life of 100000 writes, with unlimited reads.
PaulS:
Okay, Easy enough. I was under the impression that reading EEPROM reduces the life of it as well.
Thanks,
  • B
Blade2021:
No. EEPROM reads are nearly free. They do not cause any wear and they are almost as fast as reading from SRAM.
