EEPROM reading values problem[SOLVED]!!
Sorry my mistake!!!The whole code is:
#include <EEPROM.h>
const int analogInPin = A0;  // Analog input pin that the potentiometer is attached to
const int analogOutPin = 9;  // Analog output pin that the LED is attached to
 int sensorValue = 0;        // value read from the pot
 int outputValue = 0;        // value output to the PWM (analog out)
 int storeData[10];
 int cData = 0;
  // initialize serial communications at 9600 bps:
  Serial.print("Units         to        Volts\n");
  Serial.print("-------------------------------\n");
   if( cData <= 10 ){
      // read the analog in value:
      sensorValue = analogRead(analogInPin);
      // change the analog out value:
      analogWrite(analogOutPin, sensorValue);
      //write these 10 values to eeprom
      EEPROM.write(cData, sensorValue);
      // print the results to the serial monitor:
      Serial.print("sensor = " );
      Serial.print(sensorValue);
      Serial.print("\t output = ");
      Serial.println(((sensorValue*5.0)/1024),4); //output result into volts
                                                  //with 4 digits precision
      // wait 10 milliseconds before the next loop
      // for the analog-to-digital converter to settle
      // after the last reading:
      cData++;
      delay(10);
    byte serialData = Serial.read();
    //Serial.println("Press l to load values from eeprom");
    if ((char)serialData =='l')  {
      int addr = 0;
      while (addr <= 10) {
        // read a byte from the current address of the EEPROM
        byte value = EEPROM.read( addr  );
        Serial.print( addr );
        Serial.print("\t");
        Serial.print(value, DEC);
        Serial.println();
        addr++;
}// ...loop()
Thanks!!
