EEPROM STORAGE CODE HELP
Hi
Can anyone help to explain the following Statement
void StorageClass::writeS3State(int patchno, bool state)
	byte bit_fld = EEPROM.read(Offset(patchno) + 3);
  	if (state)
		bit_fld |= 1 << 0;
		bit_fld &= ~(1 << 0);
	EEPROM.write(Offset(patchno) + 3, bit_fld);
Thank you.
It writes a zero or a one to the first bit of an address determined by the Offset() function. Except it adds 3 to the offset for no explainable reason.
Thanks for that :slight_smile:
is the offset it refers to 16 this section of the code
int StorageClass::Offset(int patchno)
return (patchno * 16) + 16;
// Memory stucture:
// byte 0 -> init marker
// byte 1 -> midi channel
// byte 2 -> maximum bank
// byte 4/5 -> PDL1 min
// byte 6/7 -> PDL1 max
// byte 8/9 -> PDL2 min
// byte 10/11 -> PDL2 max
// byte 12 -> Performance mode
// from byte 16 and further
// Each patch, 16 bytes long:
// 0 : ProgChangeNo
// 1 : S1 CC
// 2 : S2 CC
// 3 : S1/S2 state and vol->wah (bitwise)
// 4..15: 12-character name
// 16 : S3 CC
// 17 : S3 State
#include "Storage.h"
#include "constants.h"
void StorageClass::init()
  if (EEPROM.read(0) != 127)
    EEPROM.write(0,127);
   // for (int i = 0; i < 4024; i++)
    // EEPROM.write(i, 0);
    writeChannel(1);
    writeMaxBank(12);
    writePatchName(0, "JMP1");
    writePatchName(1, "CleanChorus");
    writePatchName(2, "Clean");
    writePatchName(3, "Lead");
    writePatchName(4, "JMP1");
    writePatchName(5, "CleanCh");
    writePatchName(6, "Cry");
    writePatchName(7, "Luke");
    writePatchName(8, "JMP1!");
    writePatchName(9, "Clubclean");
    writePatchName(10, "Country");
    writePatchName(11, "CountryTS");
	for (int i = 0; i < 63; i++)
		writeS1CC(i, 80);
		writeS2CC(i, 82);
                writeS3CC(i, 85);
	for (int i = 0; i < 4; i++)
		writeS1State(i, true);
	writeS2W2VState(6, true);
byte StorageClass::readChannel()
  EEPROM.read(1);
void StorageClass::writeChannel(byte channel)
  EEPROM.write(1, channel);
byte StorageClass::readMaxBank()
  EEPROM.read(2);
void StorageClass::writeMaxBank(byte maxbank)
  // 63 programs max
  maxbank = min(byte(63 / banksize), maxbank);
  EEPROM.write(2, maxbank);
String StorageClass::readPatchName(int patchno)
  // start in EEPROM from position 16, max = 1007 => 63 patches max!
  // 0 : ProgChangeNo (not used)
  // 1 : S1 CC
  // 2 : S2 CC
  char buf[13];
  for (int i = 0; i < 12; i++)
	  buf[i] = EEPROM.read(Offset(patchno) + i + 4);
  buf[12] = 0;
  return String(buf);
void StorageClass::writePatchName(int patchno, char *patchname)
  int len = strlen(patchname);
    if (i < len)
		EEPROM.write(Offset(patchno) + i + 4, patchname[i]);
		EEPROM.write(Offset(patchno) + i + 4, ' ');
byte StorageClass::readS1CC(int patchno)
	return EEPROM.read(Offset(patchno) + 1);
void StorageClass::writeS1CC(int patchno, byte CC)
	EEPROM.write(Offset(patchno) + 1, CC);
  byte StorageClass::readS2CC(int patchno)
	return EEPROM.read(Offset(patchno) + 2);
void StorageClass::writeS2CC(int patchno, byte CC)
	EEPROM.write(Offset(patchno) + 2, CC);
byte StorageClass::readS3CC(int patchno)
	return EEPROM.read(Offset(patchno) + 17);
void StorageClass::writeS3CC(int patchno, byte CC)
	EEPROM.write(Offset(patchno) + 17, CC);
bool StorageClass::readS1State(int patchno)
	return (EEPROM.read(Offset(patchno) + 3) & 0x1) == 0x1;
void StorageClass::writeS1State(int patchno, bool state)
  	if (state)
		bit_fld |= 1 << 0;
bool StorageClass::readS2State(int patchno)
	return (EEPROM.read(Offset(patchno) + 3) & 0x2) == 0x2;
void StorageClass::writeS2State(int patchno, bool state)
	if (state)
		bit_fld |= 1 << 1;
		bit_fld &= ~(1 << 1);
  bool StorageClass::readS2W2VState(int patchno)
	return (EEPROM.read(Offset(patchno) + 3) & 0x4) == 0x4;
void StorageClass::writeS2W2VState(int patchno, bool state)
	if (state)
		bit_fld |= 1 << 2;
		bit_fld &= ~(1 << 2);
void StorageClass::writePDL1Min(int Value)
    EEPROM.write(4,highByte(Value));
    EEPROM.write(5,lowByte(Value));
int StorageClass::readPDL1Min()
    return word(EEPROM.read(4),EEPROM.read(5));
void StorageClass::writePDL1Max(int Value)
    EEPROM.write(6,highByte(Value));
    EEPROM.write(7,lowByte(Value));
int StorageClass::readPDL1Max()
    return word(EEPROM.read(6),EEPROM.read(7));
  void StorageClass::writePDL2Min(int Value)
    EEPROM.write(8,highByte(Value));
    EEPROM.write(9,lowByte(Value));
int StorageClass::readPDL2Min()
    return word(EEPROM.read(8),EEPROM.read(9));
void StorageClass::writePDL2Max(int Value)
    EEPROM.write(10,highByte(Value));
    EEPROM.write(11,lowByte(Value));
int StorageClass::readPDL2Max()
    return word(EEPROM.read(10),EEPROM.read(11));
byte StorageClass::readPrgChg(int patchno)
  // 1 : S1 CC
  // 2 : S2 CC
  return EEPROM.read(Offset(patchno));
void StorageClass::writePrgChg(int patchno, byte PrgChg)
    EEPROM.write(Offset(patchno), PrgChg);
void StorageClass::ResetProgramMap()
    for(int i = 0; i < 63; i++)
      writePrgChg(i, i);
void StorageClass::writePerfMode(boolean Value)
    EEPROM.write(12,Value ? 1 : 0);
boolean StorageClass::readPerfMode()
    return EEPROM.read(12) == 1;
bool StorageClass::readS3State(int patchno)
	return (EEPROM.read(Offset(patchno) + 3) & 0x8) == 0x8;
  	if (state)
		bit_fld |= 8 << 0;
		bit_fld &= ~(8 << 0);
