EEPROM.update problem(newbie)
Hi.I am new in arduino. I am trying to program a code to allow user to change or update the value in eeprom.
I managed to run the code successfully but I seem to have a problem with the eeprom update. When I tried to read the data in the eeprom, it is still the old data,not the updated one. Can someone help me :’(
#include <EEPROM.h>
String YesNo;
float newval;
float val = 0.0001598125;
int address = 0;
  serial();
  Serial.println("Do you want to change the value?");//Prompt user for input
    while(Serial.available()==0){}
    YesNo=Serial.readString(); //Read user input
    if(YesNo=="yes"){
      Serial.println("Enter new value");
      newval=Serial.parseFloat();
      //float a= EEPROM.get(address);
      Serial.print("The value now is ");
      Serial.println(newval,10);
      EEPROM.update(address,newval);
    else{
      Serial.print("The value is not changed.");
void serial(){
  float a = EEPROM.get( address, val );  //Read value from EEPROM starting at 'address'.
  Serial.println("Welcome");
  Serial.print("Current value is ");
  Serial.println(a,10);
EEPROM.update()/EEPROM.read() only deals with single bytes.
You want EEPROM.get() & EEPROM.put() to work with floats (or other large types).
Your code appears to work correctly by simply changing EEPROM.update(address,newval); to EEPROM.put(address,newval);. Just in case you are wondering, the 'put()' method does use the update() method internally.
Check the link in my sig for more info.
pYro_65:
Your code appears to work correctly by simply changing EEPROM.update(address,newval); to EEPROM.put(address,newval);. Just in case you are wondering, the ‘put()’ method does use the update() method internally.
yess! thank you so much that really helps! :smiley:
