I was just wondering what the difference between these to is?
I tried googling but couldn't find anything.
EEPROM.write vs EEPROM.update
update checks first if the value needs to change, so it does a read and if your value is different then it writes it.
this is because you can only write ~100,000 times into EEPROM and then your cell is likely dead (it wears out), so it's not a good idea to write when the value is the same.
okay,
thanks mate
captain_morgan_1999:
I tried googling but couldn't find anything.EEPROM.write vs EEPROM.update
Sure you used google ?
A google search on;
Arduino EEPROM.update
and
Both point to the reference page that explains the difference.
EEPROM.put() also uses the update method, which is useful for writing data types longer than a byte (can also be used with a single byte).
