EEPROM
Bonjour, novice en Arduino et un peut âgé, je débute avec un message d’erreur!
Arduino : 1.6.12 (Windows 10), Carte : “Arduino/Genuino Uno”
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Eric\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Eric\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Eric\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10612 -build-path C:\Users\Eric\AppData\Local\Temp\arduino_build_440220 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Eric\AppData\Local\Temp\arduino_modified_sketch_743064\DigitalPotControl.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Eric\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Eric\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Eric\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10612 -build-path C:\Users\Eric\AppData\Local\Temp\arduino_build_440220 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Eric\AppData\Local\Temp\arduino_modified_sketch_743064\DigitalPotControl.ino
Using board ‘uno’ from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core ‘arduino’ from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used…
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard” “C:\Users\Eric\AppData\Local\Temp\arduino_build_440220\sketch\DigitalPotControl.ino.cpp” -o “nul”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\EEPROM\src” “C:\Users\Eric\AppData\Local\Temp\arduino_build_440220\sketch\DigitalPotControl.ino.cpp” -o “nul”
“C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++” -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10612 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard” “-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\EEPROM\src” “C:\Users\Eric\AppData\Local\Temp\arduino_build_440220\sketch\DigitalPotControl.ino.cpp” -o “C:\Users\Eric\AppData\Local\Temp\arduino_build_440220\preproc\ctags_target_for_gcc_minus_e.cpp”
C:\Users\Eric\AppData\Local\Temp\arduino_modified_sketch_743064\DigitalPotControl.ino:31:19: fatal error: DHT.h: No such file or directory
#include <DHT.h>
compilation terminated.
Utilisation de la bibliothèque EEPROM version 2.0 dans le dossier: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\EEPROM
exit status 1
Erreur de compilation pour la carte Arduino/Genuino Uno
Merci de votre aide.
Eric
sacoer:
That’s just a helpful message to tell you which EEPROM library is being used. You can probably just ignore it.
sacoer:
#include <DHT.h>
That’s the error message that you need to worry about. The problem is you need to install the DHT library.
Merci de votre aide, ça marche!
Bien a vous
