Hi all,
I'm trying to use the functions to read and write data from the EEPROM using what is described here: Arduino Playground - EEPROMWriteAnything.
Oh well, i'll include the code anyway:
#include <EEPROM.h>
template <class T> int EEPROM_writeAnything(int ee, const T& value)
const byte* p = (const byte*)(const void*)&value;
int i;
for (i = 0; i < sizeof(value); i++)
EEPROM.write(ee++, *p++);
return i;
template <class T> int EEPROM_readAnything(int ee, T& value)
byte* p = (byte*)(void*)&value;
int i;
*p++ = EEPROM.read(ee++);
return i;
Can someone point me in the right direction (code wise) on how to save/read the following data:
boolean initialConfig = 0;
double P1[7]={21,21,21,21,21,16,16};
double P2[7]={20,20,20,20,20,20,20};
double P3[7]={21,21,21,21,21,21,21};
double P4[7]={16,16,16,16,16,16,16};
long T1[7]={23400,23400,23400,23400,23400,30600,30600}; // 6:30 time in seconds since start of day at 0:00:00
long T2[7]={30600,30600,30600,30600,30600,30600,30600}; // 8:30
long T3[7]={72000,72000,72000,72000,72000,72000,72000}; // 20:00
long T4[7]={84600,84600,84600,84600,84600,84600,84600}; // 23:30
If i understood it well, the P1,P2,P3,P4 contain all 1-byte values, while T1,T2,T3,T4 contain 2-byte values, right?
So the following code should work i guess: (not tried yet)
EEPROM_readAnything(0, initialConfig); //check if there is already a config in the EEPROM (address 0 should be 1)
if (initialConfig == 0) saveInitialConfig();
void saveInitialConfig() {
initialConfig = 1;
int bytesWritten = EEPROM_writeAnything(0, initialConfig);
bytesWritten += EEPROM_writeAnything(bytesWritten, P1);
bytesWritten += EEPROM_writeAnything(bytesWritten, P2);
bytesWritten += EEPROM_writeAnything(bytesWritten, P3);
bytesWritten += EEPROM_writeAnything(bytesWritten, T1);
bytesWritten += EEPROM_writeAnything(bytesWritten, T2);
bytesWritten += EEPROM_writeAnything(bytesWritten, T3);
bytesWritten += EEPROM_writeAnything(bytesWritten, T4);
But afterwards, how do I know where I should start reading the EEPROM to get for ex. T2 ?
If there are better ways to accomplish this, I'm happy to hear it
Greetings,
EriSan500
