EEPROMAnything() beginner question.
Hello,
I just want to start off by thanking all the people who support this informative forum and i’m sorry if this question had already been answered, but as I’m still learning , I have a question regarding the EEPROMAnything library,
In these two small codes that I’m running:
#include <EEPROM.h>
#include <EEPROMAnything.h>
int address =6;
int b = 1234 ;
int output = 0;
void setup(){
EEPROM_writeAnything ( address, b);
output= EEPROM_readAnything(address, b);
Serial.print(address);
Serial.print("\t");
Serial.print(output);
void loop(){}
my Serial output looks like this : 6 “2”
int = 2 bytes ,
Is it possible if I can get it to write my data “1234” , ( higher than 255) ?
Also, in this short code,
#include <EEPROM.h>
    int n = 0;
    int by = 1234;
    //Serial.println(by, HEX);
    n = EEPROM_writeAnything(0, by);
    Serial.print("Wrote bytes: ");
    Serial.println(n);
    by = 1234;
    n = EEPROM_readAnything(0, by);
    Serial.print("Read bytes: ");
    Serial.println(n);
    Serial.println("-------");
    void loop(){
I get : Wrong bytes: 2
Read bytes: 2
If possible , can you please enlighten me , why its not writing my values and reading 2 bytes instead ?
Thanks
I don't understand your first problem. An int is 2 bytes and can have numbers between -32000 and +32000 ( whether 2 to the 15th power is precisely ). An unsigned int can be between 0 and 65000. An int is not limited to 255, you are thinking of a 1 byte number.
The problem is that you can only write a byte to each address, which means that the highest number you can write to a single address is 255.
I have been using this code for quite a few years (not sure of the original author, sorry) which effectively writes a 2 byte integer to a specified address plus the next one - and reads the same way.
//This function will write a 2 byte integer to the eeprom at the specified address and address + 1
void EEPROMWriteInt(int p_address, int p_value)
	byte lowByte = ((p_value >> 0) & 0xFF);
	byte highByte = ((p_value >> 8) & 0xFF);
	EEPROM.write(p_address, lowByte);
	EEPROM.write(p_address + 1, highByte);
//This function will read a 2 byte integer from the eeprom at the specified address and address + 1
unsigned int EEPROMReadInt(int p_address)
	byte lowByte = EEPROM.read(p_address);
	byte highByte = EEPROM.read(p_address + 1);
	return ((lowByte << 0) & 0xFF) + ((highByte << 8) & 0xFF00);
There are some more extensive libraries also available - you might want to have a look at http://playground.arduino.cc//Code/EEPROMex
I’m not sure if anyone has combined the functionality of the EEPROMAnything library with the ability to read/write different data formats.
Cheers
Thank you guys very much for your suggestions, and thanks @Magicj for this code, I'm still learning how to use the EEPROMEx lib. But I was just more curious in the EEPROMAnything library., and I wanted to test it out by running a small code. The EEPROM.h can write a single byte =0-255 and int = 2 bytes,
excuse my lame question, but In the first code, shouldn't it be able to write/read a 2 byte int ( "1234" ) using the "EEPROMAnything.h" or is the code just incorrectly written or is it just, I can't use the eepromAnything lib to write values higher than 255 ?? Thank you
I think I get it know guys, since 1234 cannot be stored in one address because 1234 is too big to be stored in a single byte, so it is stored in address 0 and address 1.
so it would look something like this,
Code:
#include <EEPROM.h>
void setup(){
 int address =6;
 int b = 1234;
int output ;
EEPROM.write ( address, highByte (b));
EEPROM.write( 1, lowByte (b));
 output= (EEPROM.read(address) << 8) + EEPROM.read (1);
Serial.print("\t");
void loop(){}
or
#include <EEPROM.h>
  int a = 3333;
  int address=0;
  int output;
  EEPROM_writeAnything(address, a);
  EEPROM_readAnything(address,output);
sorry but can I ask a different question, as I’m not sure, if its more appropriate to open a new topic or just continue here, but its related to eeprom ,
using two switches, to cycle through characters on the selected spot of lcd and change positions.
#include <LiquidCrystal.h>
const int button1 = 1;
const int button2 = 10;
//char* secretCode = "0241";
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int pos = 0;
int cpos1 = 0;
  String output = "----";
 lcd.begin(16,2);
 lcd.setCursor(3, 0);
 lcd.print("Enter your");
 lcd.setCursor(1,1);
 lcd.print("Social security");
 delay(3000);
 lcd.clear();
 lcd.setCursor(0,0);
 lcd.print (output);
 //Setup some buttons
 pinMode (button1, INPUT);
 pinMode (button2, INPUT);
 //Turn the internal resistors on
 digitalWrite(button1, HIGH);
 digitalWrite(button2, HIGH);
  //Change the position
  if (digitalRead(button1) == LOW)
    pos ++;
    cpos1 ++;
    delay (500);
    if (pos >= 5 )
     pos = 40;
     cpos1 = 0;
    if (pos >= 45 )
     pos = 0;
     cpos1 = 0;
  // Cycles through the characters on the selected spot
  if (digitalRead(button2) == LOW)
   lcd.clear();
   lcd.print(output);
   output [pos] = (output [pos] ++);
   lcd.clear();
   lcd.print(output);
   delay (400);
 lcd.setCursor (cpos1, 0);
   lcd.blink();
But i was wondering, if it is possible to store any 4 characters I choose and store it in the eeprom, in which this 4 digit can only be useful/usable once , just like a coupon; can only be used once, so say I choose 0241 (B) and store it in the eeprom so like
int B= 0241;
int address= 6;
EEPROM.write ( address, highByte (B));
EEPROM.write( 7, lowByte (B));
say,
if i choose 0241 as my 4 digits, save that into the memory and proceed to the next step. But if i reset it again and say i entered different characters like 1299 or same characters again, 0241, , it’d say something like
if pos1=1299
lcd.print(“not genuine”);
and cannot proceed , return to initialize
or
if B=0241
lcd.print(“already been used”)
cannot proceed, return.
I’m not really sure, if i can incorporate this in my above code or if it can even be done. But mainly, i’m not sure whats the best approach to do this, whether to use a while, if or for loop ?
sorry if this looks lame to you but really any ideas are welcome, thanks :slight_smile:
There are two ways to store numbers. Actually, there are more, but let's concentrate on two.
One is binary. EEPROM stores binary in blocks of 8 bits which allows 0-255 (or -128 to 127) to be represented in one address. To store larger binary numbers, you have to spread the bits across blocks. A 16-bit 'int' requires two EEPROM blocks, a 32-bit 'long' requires four EEPROM blocks.
The other is ASCII. This is where you store each digit in a block. So 0241 would be stored as 0 in adress 0, 2 in address 1, 4 in address 2, and 1 in address 3.
Which you want to use depends on... what you want to do. :)
Binary is usually more space-efficient. ASCII is "easier" to encode and decode (for some definitions of "easier").
One is binary
No, it's all binary.
Internally, yes. But in your C source code you can just use a single digit numbers or a single-quoted ASCII character and let the compiler make it binary for you. ;)
EEPROM.write ( address, '1'); EEPROM.write ( address, 1);
Of course, you'll need to read it back out the same way. 1 does not equal '1'.
Thanks guys, i got it now, single byte = 0-255 aka 8bits aka not enough, if you're dealing with "int" or"long", so more address are required for data storage. I was wondering if my above idea, with the coupon, whether it is do-able using the eeprom approach or if there's a better apporach or do i need to use the DB.h? thanks
Debuginlove0: I was wondering if my above idea, with the coupon, whether it is do-able using the eeprom approach
Yes, quite do-able. In order to store a leading 0 you will need to use the ASCII approach.
Hi, Just got a chance to go on my PC again and I just wanted to thank everyone one for their i/ps. thanks :).
