EEPROMEx example code not compiling
Downloaded EEPROMex library from GiTHub and the examples will not compile
Example EEPROMEx runs fine
Example EEPROMBackup gives compile errors
EEPROMBackup:23: error: ‘EEPROMSizeUno’ was not declared in this scope
EEPROMBackup:53: error: expected constructor, destructor, or type conversion before ‘<’ token
EEPROMBackup.pde: In function ‘void setup()’:
EEPROMBackup:61: error: ‘EEPROM’ was not declared in this scope
EEPROMBackup:61: error: ‘EEPROMSizeUno’ was not declared in this scope
EEPROMBackup:70: error: ‘timeBackup’ was not declared in this scope
EEPROMBackup.pde: In function ‘void loop()’:
EEPROMBackup:77: error: ‘timeBackup’ was not declared in this scope
Example EEPROMVar give the following compile errors
EEPROMVar:17: error: variable or field ‘readAndWriteVar’ declared void
EEPROMVar:17: error: ‘EEPROMVar’ was not declared in this scope
EEPROMVar:17: error: expected primary-expression before ‘float’
EEPROMVar.pde: In function ‘void setup()’:
EEPROMVar:50: error: ‘EEPROM’ was not declared in this scope
EEPROMVar:50: error: ‘EEPROMSizeUno’ was not declared in this scope
EEPROMVar:57: error: ‘EEPROMVar’ was not declared in this scope
EEPROMVar:57: error: expected primary-expression before ‘float’
EEPROMVar:57: error: expected `;’ before ‘float’
EEPROMVar:59: error: ‘eepromFloat’ was not declared in this scope
EEPROMVar:59: error: ‘readAndWriteVar’ was not declared in this scope
Can anyone tell me what to change to get the examples to work???
Bill
Please link the code you are trying to compile and say what version of the IDE you are trying to compile it on.
Thanks for reply;
Attached are the two example files(no modifications from downloaded files) that will not compile.
I am using 1.5.4.r2
Bill
EEPROMBackup.pde (3.23 KB)
EEPROMVar.pde (1.95 KB)
And a link to the two libraries?
#include <EEPROMex.h>
#include <EEPROMBackupVar.h>
Given that the extension of the files you posted is .pde it suggests it is a very old file and not compatible with 1.x versions of the arduino IDE.
Attached are the files.
The file dates shown in the download show July 12, 2012 for the backup and var files; Jan 20,2013 for the Ex file.
This is the download link. GitHub - thijse/Arduino-Libraries: Arduino Libraries
Bill
EEPROMEx.h (4.64 KB)
EEPROMBackupVar.h (4.38 KB)
The EEPROMBackupVar.h file is trying to use the getAdress() method, which doesn't exist. Change getAdress() to getAddress() in two places, and the code compiles.
Paul:
Thank you. EEPROMVar and EEPROMBackup examples now work; I also had to change getAdress to getAddress in EEPROMVar.pde
Thanks again; how do we get the creator to update the download??
Bill Lynn
It's posted on github. Anyone can check the files out, fix them, and check them back in. Anyone with a github account, anyway.
Personally, I won't get one because I hate the piss-poor layout that the site uses. Making people hunt all over the place for the download button is asinine.
IO HAVE A github ACCOUNT BUT AM NOT ADEPT AT USING IT SO I FOUND THE CREATORS WEBSITE AND SENT HIM A MESSAGE. THANKS AGAIN FOR YOUR HELP
bILL
Hi William,
Thanks for your bug reports. I packaged a version that includes a lot of bugfixes. It will fix the issues you describe, as well as included Teensy support. Special thanks to the people who have submitted fixes:
You can download the updated library at the same place as the previous: http://thijs.elenbaas.net/downloads/?did=3
Cheers, Thijs
