Efficient and simple DHT library
I've written a library for reading out the DHT family of temperature/humidity sensors with the following features:
  • Support for DHT11 and DHT22, AM2302, RHT03
  • Auto detect sensor model
  • Low memory footprint
  • Very small code base
Usage:
#include "DHT.h"
DHT dht;
  dht.setup(2); // data pin 2
  delay(dht.getMinimumSamplingPeriod());
  Serial.print(dht.getHumidity());
  Serial.print("\t");
  Serial.print(dht.getTemperature());
Download link: https://github.com/markruys/arduino-DHT
I liked writing it - perhaps useful for someone else...
Great. Will compare yours with my current when I have the time.
One remark: could you put the strings into PROGMEM to save a several bytes of RAM?
MarsWarrior: could you put the strings into PROGMEM to save a several bytes of RAM?
I guess you refer to:
char* DHT::getStatusString()
  switch ( DHT::getStatus() ) {
    case DHT::ERROR_NONE:
      return "OK";
    case DHT::ERROR_TIMEOUT:
      return "TIMEOUT";
    case DHT::ERROR_CHECKSUM:
      return "CHECKSUM";
    default:
      return "ERROR";
Perhaps I miss your point, but these strings already are in flash memory. The method returns a pointer to a PROGMEM location.
[quote author=Mark Ruys link=topic=171677.msg1275848#msg1275848 date=1371062083] I've written a library for reading out the DHT family of temperature/humidity sensors with the following features:
Usage:
#include "DHT.h"
DHT dht;
  Serial.print("\t");
I liked writing it - perhaps useful for someone else... [/quote]
Thanks Very much for this - i was just about implement my first one of these so will give it a whirl and report back !
regards
Craig
[quote author=Mark Ruys link=topic=171677.msg1277444#msg1277444 date=1371158343]
Perhaps I miss your point, but these strings already are in flash memory. The method returns a pointer to a PROGMEM location. [/quote] No, you did not miss my point. :blush: I got less memory usage when defining these strings as const char progmem. Weird. Must check again, might have made more sketch changes that cause the difference in RAM usage...
MarsWarrior: [quote author=Mark Ruys link=topic=171677.msg1277444#msg1277444 date=1371158343]
No, you did not miss my point. :blush: I got less memory usage when defining these strings as const char progmem. Weird. Must check again, might have made more sketch changes that cause the difference in RAM usage... [/quote] Well, you made me dig a bit deeper in the workings of PROGMEM storage, and you are right SRAM usages can be lowered! Strings in return "TIMEOUT" are copied to SRAM and returned to the caller. So I tried to rewrite getStatusString() and store the strings in PROGMEM. I don't want users of the library be bothered with strcpy_P statements, so I came up with this:
prog_char P_OK[]       PROGMEM = "OK";
prog_char P_TIMEOUT[]  PROGMEM = "TIMEOUT";
prog_char P_CHECKSUM[] PROGMEM = "CHECKSUM";
const char *DHT::getStatusString() {
  prog_char *c;
  switch ( error ) {
      c = P_CHECKSUM; break;
      c = P_TIMEOUT; break;
    default:
      c = P_OK; break;
  static char buffer[9];
  strcpy_P(buffer, c);
  return buffer;
Indeed SRAM usage drops with (2+1 + 7+1 + 8+1 - 9) = 11 bytes. The cost however is 26 bytes more code, and I don't think that's worth it, do you. Perhaps you know a more elegant way?
I mark, i will test your library on a DHT11 and report here
for the progmem question should use the arduino "F" function ?
Version 1.0 of the Arduino IDE introduced the F() syntax for storing strings in flash memory rather than RAM. e.g.
Serial.println(F("This string will be stored in flash memory"));
I tried your library and all work good with DHT11, soon will arrive a DHT22 to me and i will test with it also.
2 tips for you:
  • Instead of "arduino-DHT-master" you must use "arduino_DHT_master" because "- minus symbol" it is not allowed in arduino IDE library, and this broke the autoimport function (Sketch->Import->Add Library)
  • May use a version number in the name of the .zip so we can immediately check if is there a new version on github
FYI There exists a DHT21 too. It has a different dataformat (again), link to PDF see - http://forum.arduino.cc/index.php?topic=58531.msg1366942#msg1366942 -
I was wanting to make sure the statusString returned "OK", because of the effect a wrong reading could have in my project. So I thought this line would do it:
 while (dht.getStatusString() != "OK") {
I thought that would me 'while the status string is not ok', but it doesn't work. If I add this to the code, it shows that the status string IS indeed ok.
    Serial.println(dht.getStatusString());
This returns: OK
I'm baffled.
Hmm, I see it DOES work when I use IDE 1.6.2. It's when I use 1.0.6 that it doesn't work.
That's even more odd.
I have just tested the library with ESP8266-07 and DHT22 (Arduino IDE 1.6.5). It works fine! The only problem: I had to set the model DHT22 manually (the library detected the sensor as DHT11). Anyway, this library is good and useful. Thanks!
