Efficiently regulate from around 5V to 3.3V (for MCU) and 4.0V for SIM800L GPRS
Hello Arduino-fellows,
I think I have a tricky question for you: I would like to power an MCU with a voltage of 3.3V and a SIM800L module with a voltage of 4.0V. At the moment, I use a voltage regulator from polulu to convert the power supply voltage (4xAA NiMH) to 3.3V and just power the SIM800L over 3xAA NiMH.
Preferably, I would like to keep the 3.3V for the MCU also for the Tx,Rx ports and the attached sensors.
I have thought about using Low dropout voltage regulators (LDO), standard diodes, zener diodes but I'm not sure what's the best approach here.
Thank you!
Why those two voltages? How will you handle the logic level interface problem?
I can't imagine it is worth the effort, since neither requires a regulated supply voltage.
use lm 2596 buck module to power the sim800l module . and use pro mini or an esp32 as both are 3.3v MCU. then you can directly connect rx tx with sim module.
