hi, i am trying to write a program for an incubator that can be set to incubate different types of eggs at a time . can someone help me how to do it? here is a sample code ii had written but it is not working as expected..
#include "DHT.h"
#include <Password.h>
#include <Keypad.h>
#include <Wire.h>
#include <LiquidCrystal.h>
#define DHTPIN 22 //arduino pin where the data pin of the sensor is connected to.
#define DHTTYPE DHT22 //define the DHT22 sensor.
DHT dht (DHTPIN,DHTTYPE); // initialize sensor.
LiquidCrystal lcd (8,9,10,11,12,13); // initialize the LCD.
const byte ROWS = 4; // Four rows
const byte COLS = 3; // Four columns
char keys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
// Connect keypad ROW0, ROW1, ROW2 and ROW3 to these Arduino pins.
byte rowPins[ROWS] = {26,27,28,29}; //connect to row pinouts
// Connect keypad COL0, COL1, COL2 and COL3 to these Arduino pins.
byte colPins[COLS] = {30,31,32}; //connect to column pinouts
// Create the Keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
int relay1=23;
int relay2=24;
int relay3=25;
float temperature,humidity;
char tempF[6];
char humF[6];
pinMode (relay1,OUTPUT);
pinMode (relay2,OUTPUT);
pinMode (relay3,OUTPUT);
lcd.begin(20,4);
welcome();
dht.begin();
lcd.clear();
char y= getkey();
switch (y){
case '1':
humidity= dht.readHumidity();
temperature=dht.readTemperature();
lcd.clear();
dtostrf (temperature,3,1,tempF); // functions to convert sensor readings to string variables for display.
dtostrf (humidity,3,1,humF);
lcd.setCursor(0,0);
lcd.print ("Tempeture: ");
lcd.print (tempF);
lcd.setCursor(0,1);
lcd.print ("humidity: ");
lcd.print (humF);
lcd.print ("%");
if (humidity >60)
digitalWrite(relay3,LOW);
digitalWrite (relay3,HIGH);
if (humidity <50)
digitalWrite(relay2,LOW);
digitalWrite (relay2,HIGH);
delay (500);
case '2':
lcd.setCursor(0,0);
lcd.print (tempF);
lcd.setCursor(0,1);
lcd.print (humF);
lcd.print ("%");
if (humidity >48.5)
if (humidity <40)
case '3':
lcd.setCursor(0,0);
lcd.print (tempF);
lcd.setCursor(0,1);
lcd.print (humF);
lcd.print ("%");
if (humidity >55)
if (humidity <50)
default:
lcd.print("WRONG CHOOICE");
void welcome(){
lcd.clear();
lcd.print("****WELCOME*****");
lcd.setCursor(0,1);
lcd.print("SELECT TYPE OF EGG");
delay(5000);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("1: CHICKEN");
lcd.setCursor(0,1);
lcd.print("2: DUCKK");
lcd.setCursor(0,2);
lcd.print("3: QUAIL");
char getkey()
lcd.clear();
char key=keypad.getKey();
keypad.setDebounceTime(250);
if (key!=NO_KEY)
return key;
lcd.print("NO KEY PRESSED");
