Eggbot aka Spherebot with bipolar 28BYJ-48 and Inkscape
Hello,
I hacked the 28BYJ-48 to bipolar, connected everything to a Protoneer-CNC shield with A4988 set to 200mV. Works, somehow... I have tried GitHub-Yura80/Eggduino and assigned all pins correctly. I have also tried full-stepping, half-stepping and 1/16th stepping (setting MS0-MS1-MS2 jumpers on the board and changing values in eggduino.ino). In Inkscape with eggboat-extension 2.5.0 I've set values for "speed" on values 50-100-250-500-1000 and tried manual control. Loading a testpattern, I hit the button. Servo works fine, but the motors don't.
Has anybody ever tried to build a simple eggbot with bipolar 28BYJ-48 steppers?
Any hint would be appreciated. Is there different firmware out there I could try?
Thank you very much.
Have you loaded code to just power the stepper to see if it works?
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
There is no "circuit" to draw: Arduino Uno + Protoneer-CNC-Shield + 2x A4988 driver
I uploaded grbl and tested the steppers, they are working fine (and surprisingly rather "fast").
I tried Inkscape 0.91 on my Ubuntu-Linux with EggBot 2.5 and 2.7.1 without success. I don't know why.
So maybe I should try and get grbl running with the z-axis modified to controll the servo going up/down for the drawing pen.
Or maybe someone knows a different software to run an eggbot?
