Hello guys i just try this code on arduino ide 1.8 but it show me this message error
Arduino: 1.8.19 (Windows 7), Board: "Arduino Yún"
C:\Users\Pc\AppData\Local\Temp\arduino_modified_sketch_399649\ECGExampleSerial.ino: In function 'void loop()':
ECGExampleSerial:11:9: error: 'eHealth' was not declared in this scope
ECG = eHealth.getECG(); // Utilise la méthode getECG() pour obtenir la valeur du capteur ECG
exit status 1
option enabled in File -> Preferences.
and this this the code
#include <eHealth.h>
float ECG;
Serial.print("ECG value : ");
Serial.print(ECG, 2);
Serial.print(" V");
Serial.println("");
delay(1);
and this is the eHealth.cpp code
// include this library's description file
#include "eHealth.h"
getECG(void);
// Accelerometer Variables and definitions *
//! not the wire library, can't use pull-ups
#include "i2c.h"
//! Breakout board defaults to 1, set to 0 if SA0 jumper is set
#define SA0 1
#if SA0
#define MMA8452_ADDRESS 0x1D //! SA0 is high, 0x1C if low
#else
#define MMA8452_ADDRESS 0x1C
#endif
#define int1Pin 2
#define int2Pin 3
//! Set the scale below either 2, 4 or 8.
const byte scale = 2;
//! Set the output data rate below. Value should be between 0 and 7.
//! 0=800Hz, 1=400, 2=200, 3=100, 4=50, 5=12.5, 6=6.25, 7=1.56
const byte dataRate = 0;
// BloodPressureSensor tables *
const int pressures[] = {85, 87, 88, 90, 91, 92, 94, 96, 98, 100, 101, 102, 103, 105, 106, 107, 108, 110, 112, 114, 122, 123, 124, 131, 137, 147, 153, 156 };
//! 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27
const double voltages[] = {1.120, 1.16, 1.1685, 1.180, 1.1860 , 1.21, 1.2227, 1.24, 1.254, 1.265, 1.27, 1.275, 1.2825, 1.290, 1.296, 1.316, 1.33 , 1.34 ,1.37, 1.39, 1.4535, 1.46, 1.465, 1.51, 1.557, 1.64, 1.68, 1.71};
// Constructor of the class *
//! Function that handles the creation and setup of instances
eHealthClass::eHealthClass(void) { /*void constructor*/ }
// Public Methods *
//! Name: initPositionSensor() *
//! Description: Initializes the position sensor and configure some values. *
//! Param : void *
//! Returns: void *
//! Example: eHealth.initPositionSensor(); *
eHealthClass::eHealthClass() {
position = NULL;
void eHealthClass::bodyPosition() {
position = new uint8_t[6];
// Initialisation des valeurs du tableau position
void eHealthClass::clearPosition() {
if (position != NULL) {
delete[] position;
position = NULL;
// Implémentation des autres méthodes de la classe eHealthClass...
void eHealthClass::initPositionSensor(void)
byte c;
/* Set up the interrupt pins, they're set as active high, push-pull */
pinMode(int1Pin, INPUT);
digitalWrite(int1Pin, LOW);
pinMode(int2Pin, INPUT);
digitalWrite(int2Pin, LOW);
/* Read the WHO_AM_I register, this is a good test of communication */
c = readRegister(0x0D); // Read WHO_AM_I register
if (c == 0x2A) { // WHO_AM_I should always be 0x2A
initMMA8452(scale, dataRate); // init the accelerometer if communication is good
Serial.println("MMA8452Q is online...");
Serial.print("Could not connect to MMA8452Q: 0x");
Serial.println(c, HEX);
//while (1); // Loop forever if communication doesn't happen
//! Name: initBloodPressureSensor() *
//! Description: Initializes the BloodPressureSensor sensor. *
//! Param : floar parameter with correction value *
//! Returns: void *
//! Example: eHealth.initBloodPressureSensor(); *
void eHealthClass::initBloodPressureSensor(float parameter)
float pressureMAPactual = 0;
float pressureMAP = 0;
float pressure = 0; //Pressure sensor lecture
float pulse = 0; //Voltage pulses
float voltage = 0;
unsigned char state = 0;
unsigned int initial = 0;
float pressuremmHG = 10;
unsigned int i = 0;
boolean rank = 0;
double pastVoltages[30];
double furtherVoltages[30];
double aux[50];
initial = digitalRead(5);
/*while (initial == 1) {
initial = digitalRead(5); //Waiting for pulse.
if (initial == 0) {
char cont = 0;
Serial.print("Measurement started ...............");
Serial.println("Wait please................");
state = 1;
delay(3000); // Wait for 5 seconds to eliminate noise measurement
pressureMAPactual=0;
pressure = 0;
while (initial == 0) {
pressure = analogRead(4);// ----> Reading pressure sensor
pulse = analogRead(5); // ----> Reading voltage pulses
initial = digitalRead(5); // ----> Start measure
if ( cont == 30 ) {
cont = 0;
aux[cont] = ( pressure * 5 ) / 1023;
cont ++;
if (pressureMAPactual < pulse) { // Save max value
pressureMAPactual = pulse;
pressureMAP = pressure;
for (int i = 0; i<30; i++) {
pressure = analogRead(4);// Reading pressure sensor
furtherVoltages[i] = (pressure * 5) / 1023;
pastVoltages[i] = aux[i];
voltage = 0; // Clear variable
for (int i = 0; i <30; i++) {
voltage = voltage + furtherVoltages[i] + pastVoltages[i];
} // Average value
voltage = (voltage / 60) + parameter ; // Correction value
Serial.print("Average voltage : ");
Serial.println(voltage);
if (state == 1) {
i = 0;
rank = 0;
while ((rank == 0) & (i <27)) { // Searching for range int table of voltages
if (voltages[i] >= voltage ) {
rank = 1;
i++;
i--;
pressuremmHG = pressures[i-1] + (voltage - voltages[i-1]) * 100; // Asign pressure LUP.
systolic = (int(pressuremmHG));
diastolic = (int((pressuremmHG * 0.54) / 0.85 ) );
state = 0;
pressureMAP = 0;
pressuremmHG = 0;
voltage = 0;
initial = 1;
//! Name: initPulsioximeter() *
//! Description: Initializes the pulsioximeter sensor. *
//! Param : void *
//! Returns: void *
//! Example: eHealth.initPulsioximeter(); *
void eHealthClass::initPulsioximeter(void)
// Configuring digital pins like INPUTS
pinMode(13, INPUT); pinMode(12, INPUT);
pinMode(11, INPUT); pinMode(10, INPUT);
pinMode( 9, INPUT); pinMode( 8, INPUT);
pinMode( 7, INPUT); pinMode( 6, INPUT);
// attach a PinChange Interrupt to our pin on the rising edge
//! Name: getTemperature() *
//! Description: Returns the corporal temperature. *
//! Param : void *
//! Returns: float with the corporal temperature value. *
//! Example: float temperature = eHealth.getTemperature(); *
float eHealthClass::getTemperature(void)
//Local variables
float Temperature; //Corporal Temperature
float Resistance; //Resistance of sensor.
float ganancia=5.0;
float Vcc=3.3;
float RefTension=3.0; // Voltage Reference of Wheatstone bridge.
float Ra=4700.0; //Wheatstone bridge resistance.
float Rc=4700.0; //Wheatstone bridge resistance.
float Rb=821.0; //Wheatstone bridge resistance.
int sensorValue = analogRead(A3);
float voltage2=((float)sensorValue*Vcc)/1023; // binary to voltage conversion
// Wheatstone bridge output voltage.
voltage2=voltage2/ganancia;
// Resistance sensor calculate
float aux=(voltage2/RefTension)+Rb/(Rb+Ra);
Resistance=Rc*aux/(1-aux);
if (Resistance >=1822.8) {
// if temperature between 25ºC and 29.9ºC. R(tª)=6638.20457*(0.95768)^t
Temperature=log(Resistance/6638.20457)/log(0.95768);
if (Resistance >=1477.1){
// if temperature between 30ºC and 34.9ºC. R(tª)=6403.49306*(0.95883)^t
Temperature=log(Resistance/6403.49306)/log(0.95883);
if (Resistance >=1204.8){
// if temperature between 35ºC and 39.9ºC. R(tª)=6118.01620*(0.96008)^t
Temperature=log(Resistance/6118.01620)/log(0.96008);
else{
if (Resistance >=988.1){
// if temperature between 40ºC and 44.9ºC. R(tª)=5859.06368*(0.96112)^t
Temperature=log(Resistance/5859.06368)/log(0.96112);
else {
if (Resistance >=811.7){
// if temperature between 45ºC and 50ºC. R(tª)=5575.94572*(0.96218)^t
Temperature=log(Resistance/5575.94572)/log(0.96218);
return Temperature;
//! Name: getOxygenSaturation() *
//! Description: Returns the oxygen saturation in blood in percent. *
//! Param : void *
//! Returns: int with the oxygen saturation value *
//! Example: int SPO2 = eHealth.getOxygenSaturation(); *
int eHealthClass::getOxygenSaturation(void)
return SPO2;
//! Name: getBPM() *
//! Description: Returns the heart beats per minute. *
//! Param : void *
//! Returns: int with the beats per minute *
//! Example: int BPM = eHealth.getBPM(); *
int eHealthClass::getBPM(void)
return BPM;
//! Name: getSkinConductance() *
//! Description: Returns the value of skin conductance. *
//! Param : void *
//! Returns: float with the value of skin conductance *
//! Example: float conductance = eHealth.getSkinConductance(); *
float eHealthClass::getSkinConductance(void)
// Local variable declaration.
float resistance;
float conductance;
delay(1);
// Read an analogic value from analogic2 pin.
float sensorValue = analogRead(A2);
float voltage = sensorValue*5.0/1023;
conductance = 2*((voltage - 0.5) / 100000);
// Conductance calculation
resistance = 1 / conductance;
conductance = conductance * 1000000;
delay(1);
if (conductance > 1.0) return conductance;
else return -1.0;
//! Name: getSkinResistance() *
//! Description: Returns the value of skin resistance. *
//! Param : void *
//! Returns: float with the value of skin resistance *
//! Example: float resistance = eHealth.getSkinResistance(); *
float eHealthClass::getSkinResistance(void)
float resistance;
float conductance;
float voltage = (sensorValue * 5.0) / 1023;
delay(2);
//Conductance calcultacion
delay(2);
if (resistance > 1.0 ) return resistance;
else return -1.0;
//! Name: getSkinConductanceVoltage() *
//! Description: Returns the skin conductance value in voltage . *
//! Param : void *
//! Returns: float with the skin conductance value in voltage *
//! Example: float volt = eHealth.getSkinConductanceVoltage(); *
float eHealthClass::getSkinConductanceVoltage(void)
delay(2);
//Read analogic value from analogic2 pin.
int sensorValue = analogRead(A2);
//Convert the readed value to voltage.
float voltage = ( sensorValue * 5.0 ) / 1023;
delay(2);
return voltage;
//! Name: getECG() *
//! Description: Returns an analogic value to represent the ECG. *
//! Param : void *
//! Returns: float with the ECG value in voltage *
//! Example: float volt = eHealth.getECG(); *
float eHealthClass::getECG(void)
float analog0;
// Read from analogic in.
analog0=analogRead(0);
return analog0 = (float)analog0 * 5 / 1023.0;
//! Name: getBodyPosition() *
//! Description: Returns the current body position. *
//! Param : void *
//! Returns: uint8_t with the the position of the pacient. *
//! Example: uint8_t position = eHealth.getBodyPosition(); *
uint8_t eHealthClass::getBodyPosition(void)
static byte source;
/* If int1 goes high, all data registers have new data */
if (digitalRead(int1Pin)) {// Interrupt pin, should probably attach to interrupt function
readRegisters(0x01, 6, &data[0]); // Read the six data registers into data array.
/* For loop to calculate 12-bit ADC and g value for each axis */
for (int i=0; i<6; i+=2) {
accelCount[i/2] = ((data[i] << 8) | data[i+1]) >> 4; // Turn the MSB and LSB into a 12-bit value
if (data[i] > 0x7F) {
accelCount[i/2] = ~accelCount[i/2] + 1;
accelCount[i/2] *= -1; // Transform into negative 2's complement #
accel[i/2] = (float) accelCount[i/2]/((1<<12)/(2*scale)); // get actual g value, this depends on scale being set
/* If int2 goes high, either p/l has changed or there's been a single/double tap */
if (digitalRead(int2Pin)) {
source = readRegister(0x0C); // Read the interrupt source reg.
if ((source & 0x10)==0x10) // If the p/l bit is set, go check those registers
portraitLandscapeHandler();
delay(50); // Delay here for a little printing visibility, make it longer, or delete it
delay(100);
return bodyPos;
//! Name: getSystolicPressure() *
//! Description: Returns the value of the systolic pressure. *
//! Param : void *
//! Returns: int with the systolic pressure. *
//! Example: int systolic = eHealth.getSystolicPressure(); *
int eHealthClass::getSystolicPressure(void)
return systolic;
//! Name: getDiastolicPressure() *
//! Description: Returns the value of the diastolic pressure. *
//! Param : void *
//! Returns: int with the diastolic pressure. *
//! Example: int diastolic = eHealth.getDiastolicPressure(); *
int eHealthClass::getDiastolicPressure(void)
return diastolic;
//! Name: getAirFlow() *
//! Description: Returns an analogic value to represent the air flow. *
//! Param : void *
//! Returns: int with the airFlow value (0-1023). *
//! Example: int airFlow = eHealth.getAirFlow(); *
int eHealthClass::getAirFlow(void)
int airFlow = analogRead(A1);
return airFlow;
//! Name: printPosition() *
//! Param : uint8_t position : the current body position. *
//! Returns: void *
//! Example: eHealth.printPosition(position); *
void eHealthClass::printPosition( uint8_t position )
if (position == 1) {
Serial.println("Supine position");
} else if (position == 2) {
Serial.println("Left lateral decubitus");
} else if (position == 3) {
Serial.println("Rigth lateral decubitus");
} else if (position == 4) {
Serial.println("Prone position");
} else if (position == 5) {
Serial.println("Stand or sit position");
Serial.println("non-defined position");
//! Name: readPulsioximeter() *
//! Description: It reads a value from pulsioximeter sensor. *
//! Param : void *
//! Returns: void *
//! Example: readPulsioximeter(); *
void eHealthClass::readPulsioximeter(void)
uint8_t digito[] = {0,0,0,0,0,0};
uint8_t A = 0;
uint8_t B = 0;
uint8_t C = 0;
uint8_t D = 0;
uint8_t E = 0;
uint8_t F = 0;
uint8_t G = 0;
for (int i = 0; i<6 ; i++) { // read all the led's of the module
A = !digitalRead(13);
B = !digitalRead(12);
C = !digitalRead(11);
D = !digitalRead(10);
E = !digitalRead(9);
F = !digitalRead(8);
G = !digitalRead(7);
digito[i] = segToNumber(A, B, C ,D ,E, F,G);
delayMicroseconds(2800); //2800 microseconds
SPO2 = 10 * digito[5] + digito[4];
BPM = 100 * digito[2] + 10 * digito[1] + digito[0];
//! Name: airflowWave() *
//! Description: It prints air flow wave form in the serial monitor *
//! Param : int air with the analogic value *
//! Returns: void *
//! Example: eHealth.airflowWave(); *
void eHealthClass::airFlowWave(int air)
for (int i=0; i < (air / 5) ; i ++) {
Serial.print("..");
Serial.print("..");
Serial.print("\n");
delay(25);
//! Name: readGlucometer() *
//! Description: It reads the data stored in the glucometer *
//! Param : void *
//! Returns: void *
//! Example: eHealth.readGlucometer(); *
void eHealthClass::readGlucometer(void)
delay(100);
Serial.begin(1200);
delay(100);
Serial.print("U"); // Start communication command.
delay(1000); // Wait while receiving data.
Serial.print("\n");
if (Serial.available() > 0) {
length = Serial.read();// The protocol sends the number of measures
Serial.read(); // Read one dummy data
for (int i = 0; i<length; i++) { // The protocol sends data in this order
glucoseDataVector[i].year = Serial.read();
glucoseDataVector[i].month = Serial.read();
glucoseDataVector[i].day = Serial.read();
glucoseDataVector[i].hour = Serial.read();
glucoseDataVector[i].minutes = Serial.read();
Serial.read(); // Byte of separation must be 0x00.
glucoseDataVector[i].glucose = Serial.read();
glucoseDataVector[i].meridian = Serial.read();
Serial.read(); // CheckSum 1
Serial.read(); // CheckSum 2
//! Name: getGlucometerLength() *
//! Description: it returns the number of data stored in the glucometer *
//! Param : void *
//! Returns: uint8_t with length *
//! Example: int length = eHealth.getGlucometerLength(); *
uint8_t eHealthClass::getGlucometerLength(void)
return length;
//! Name: numberToMonth() *
//! Description: Convert month variable from numeric to character. *
//! Param : int month in numerical format *
//! Returns: String with the month characters (January, February...). *
//! Example: Serial.print(eHealth.numberToMonth(month)); *
String eHealthClass::numberToMonth(int month)
if (month == 1) return "January";
else if (month == 2) return "February";
else if (month == 3) return "March";
else if (month == 4) return "April";
else if (month == 5) return "May";
else if (month == 6) return "June";
else if (month == 7) return "July";
else if (month == 8) return "August";
else if (month == 9) return "September";
else if (month == 10) return "October";
else if (month == 11) return "November";
else return "December";
//! Name: version() *
//! Description: It check the version of the library *
//! Param : void *
//! Returns: void *
//! Example: eHealth.version(); *
int eHealthClass::version(void)
return 1;
// Private Methods *
//! This function will read the p/l source register and
//! print what direction the sensor is now facing */
void eHealthClass::portraitLandscapeHandler()
byte pl = readRegister(0x10); // Reads the PL_STATUS register
switch((pl&0x06)>>1) // Check on the LAPO[1:0] bits
case 0:
position[0] = 0;
case 1:
position[0] = 1;
case 2:
position[0] = 2;
case 3:
position[0] = 3;
if (pl&0x01) // Check the BAFRO bit
position[1] = 0;
position[1] = 1;
if (pl&0x40) // Check the LO bit
position[2] = 0;
position[2] = 1;
bodyPosition();
//! Initialize the MMA8452 registers.
void eHealthClass::initMMA8452(byte fsr, byte dataRate)
MMA8452Standby(); // Must be in standby to change registers
/* Set up the full scale range to 2, 4, or 8g. */
if ((fsr==2)||(fsr==4)||(fsr==8))
writeRegister(0x0E, fsr >> 2);
writeRegister(0x0E, 0);
/* Setup the 3 data rate bits, from 0 to 7 */
writeRegister(0x2A, readRegister(0x2A) & ~(0x38));
if (dataRate <= 7)
writeRegister(0x2A, readRegister(0x2A) | (dataRate << 3));
/* Set up portrait/landscap registers */
writeRegister(0x11, 0x40); // Enable P/L
writeRegister(0x13, 0x14); // 29deg z-lock,
writeRegister(0x14, 0x84); // 45deg thresh, 14deg hyst
writeRegister(0x12, 0x05); // debounce counter at 100ms
/* Set up single and double tap */
writeRegister(0x21, 0x7F); // enable single/double taps on all axes
writeRegister(0x23, 0x20); // x thresh at 2g
writeRegister(0x24, 0x20); // y thresh at 2g
writeRegister(0x25, 0x8); // z thresh at .5g
writeRegister(0x26, 0x30); // 60ms time limit, the min/max here is very dependent on output data rate
writeRegister(0x27, 0x28); // 200ms between taps min
writeRegister(0x28, 0xFF); // 1.275s (max value) between taps max
/* Set up interrupt 1 and 2 */
writeRegister(0x2C, 0x02); // Active high, push-pull
writeRegister(0x2D, 0x19); // DRDY int enabled, P/L enabled
writeRegister(0x2E, 0x01); // DRDY on INT1, P/L on INT2
MMA8452Active(); // Set to active to start reading
//! Sets the MMA8452 to standby mode. It must be in standby to change most register settings.
void eHealthClass::MMA8452Standby()
byte c = readRegister(0x2A);
writeRegister(0x2A, c & ~(0x01));
//! Sets the MMA8452 to active mode. Needs to be in this mode to output data
void eHealthClass::MMA8452Active()
writeRegister(0x2A, c | 0x01);
//! Read i registers sequentially, starting at address into the dest byte array.
void eHealthClass::readRegisters(byte address, int i, byte * dest)
i2cSendStart();
i2cWaitForComplete();
i2cSendByte((MMA8452_ADDRESS<<1)); // write 0xB4
i2cSendByte(address); // write register address
i2cSendStart();
i2cSendByte((MMA8452_ADDRESS<<1)|0x01); // write 0xB5
for (int j=0; j<i; j++) {
i2cReceiveByte(TRUE);
dest[j] = i2cGetReceivedByte(); // Get MSB result
i2cSendStop();
cbi(TWCR, TWEN);// Disable TWI
sbi(TWCR, TWEN);// Enable TWI
//! Read a single byte from address and return it as a byte.
byte eHealthClass::readRegister(uint8_t address)
byte data;
i2cSendStart();
i2cSendStart();
data = i2cGetReceivedByte(); // Get MSB result
i2cSendStop();
cbi(TWCR, TWEN); // Disable TWI
sbi(TWCR, TWEN); // Enable TWI
return data;
//! Writes a single byte (data) into address
void eHealthClass::writeRegister(unsigned char address, unsigned char data)
i2cSendStart();
i2cSendByte((MMA8452_ADDRESS<<1));// write 0xB4
i2cSendByte(address);// write register address
i2cSendByte(data);
i2cSendStop();
//! Assigns a value depending on body position.
void eHealthClass::bodyPosition( void )
if (( position[0] == 0 ) && (position[1] == 1) && (position [2] == 0)) {
bodyPos = 1;
} else if (( position[0] == 1 ) && (position[1] == 1) && (position [2] == 0)) {
bodyPos = 1;
} else if (( position[0] == 3 ) && (position[1] == 1) && (position [2] == 0)) {
bodyPos = 1;
} else if (( position[0] == 2 ) && (position[1] == 0) && (position [2] == 0)) {
bodyPos = 1;
} else if (( position[0] == 2 ) && (position[1] == 1) && (position [2] == 1)) {
bodyPos = 1;
} else if (( position[0] == 2 ) && (position[1] == 1) && (position [2] == 0)) {
bodyPos = 1;
} else if (( position[0] == 0 ) && (position[1] == 1) && (position [2] == 1)) {
bodyPos = 2;
} else if (( position[0] == 0 ) && (position[1] == 0) && (position [2] == 1)) {
bodyPos = 2;
} else if (( position[0] == 1 ) && (position[1] == 1) && (position [2] == 1)) {
bodyPos = 3;
} else if (( position[0] == 1 ) && (position[1] == 0) && (position [2] == 1)) {
bodyPos = 3;
} else if (( position[0] == 1 ) && (position[1] == 0) && (position [2] == 0)) {
bodyPos = 4;
} else if (( position[0] == 3 ) && (position[1] == 0) && (position [2] == 0)) {
bodyPos = 4;
} else if (( position[0] == 3 ) && (position[1] == 0) && (position [2] == 1)) {
bodyPos = 5;
} else if (( position[0] == 3 ) && (position[1] == 1) && (position [2] == 1)) {
bodyPos = 5;
} else if (( position[0] == 2 ) && (position[1] == 0) && (position [2] == 1)) {
bodyPos = 5;
bodyPos = 6;
//! Converts from 7 segments to number.
uint8_t eHealthClass::segToNumber(uint8_t A, uint8_t B, uint8_t C, uint8_t D, uint8_t E, uint8_t F, uint8_t G )
if ((A == 1) && (B == 1) && (C == 1) && (D == 0) && (E == 1) && (F == 1) && (G == 1)) {
return 0;
} else if ((A == 0) && (B == 1) && (C == 0) && (D == 0) && (E == 1) && (F == 0) && (G == 0)) {
return 1;
} else if ((A == 1) && (B == 1) && (C == 0) && (D == 1) && (E == 0) && (F == 1) && (G == 1)) {
return 2;
} else if ((A == 1) && (B == 1) && (C == 0) && (D == 1) && (E == 1) && (F == 0) && (G == 1)) {
return 3;
} else if ((A == 0) && (B == 1) && (C == 1) && (D == 1) && (E == 1) && (F == 0) && (G == 0)) {
return 4;
} else if ((A == 1) && (B == 0) && (C == 1) && (D == 1) && (E == 1) && (F == 0) && (G == 1)) {
return 5;
} else if ((A == 1) && (B == 0) && (C == 1) && (D == 1) && (E == 1) && (F == 1) && (G == 1)) {
return 6;
} else if ((A == 1) && (B == 1) && (C == 0) && (D == 0) && (E == 1) && (F == 0) && (G == 0)) {
return 7;
} else if ((A == 1) && (B == 1) && (C == 1) && (D == 1) && (E == 1) && (F == 1) && (G == 1)) {
return 8;
} else if ((A == 1) && (B == 1) && (C == 1) && (D == 1) && (E == 1) && (F == 0) && (G == 1)) {
return 9;
return 0;
// Preinstantiate Objects *
eHealthClass eHealth = eHealthClass();
also this is the eHealth.h code
#ifndef eHealthClass_h
#define eHealthClass_h
#include "Arduino.h"
class eHealthClass {
public:
eHealthClass();
void initPositionSensor();
void initBloodPressureSensor(float parameter);
void initPulsioximeter();
float getTemperature();
int getOxygenSaturation();
int getBPM();
float getSkinConductance();
float getSkinResistance();
float getSkinConductanceVoltage();
float getECG();
uint8_t getBodyPosition();
int getSystolicPressure();
int getDiastolicPressure();
int getAirFlow();
void printPosition(uint8_t position);
void readPulsioximeter();
void airFlowWave(int air);
void readGlucometer();
uint8_t getGlucometerLength();
int version();
String numberToMonth(int month);
struct glucoseData {
uint8_t year;
uint8_t month;
uint8_t day;
uint8_t hour;
uint8_t minutes;
uint8_t glucose;
uint8_t meridian;
glucoseData glucoseDataVector[8];
private:
void initMMA8452(byte fsr, byte dataRate);
void MMA8452Standby();
void MMA8452Active();
void readRegisters(byte address, int i, byte * dest);
byte readRegister(uint8_t address);
void writeRegister(unsigned char address, unsigned char data);
void portraitLandscapeHandler();
void bodyPosition();
uint8_t segToNumber(uint8_t A, uint8_t B, uint8_t C, uint8_t D, uint8_t E, uint8_t F, uint8_t G);
int systolic;
int diastolic;
int BPM;
int SPO2;
uint8_t bodyPos;
byte data[6];
int accelCount[3];
float accel[3];
uint8_t* position; // changement ici
uint8_t length;
#endif
public:
eHealthClass();
int getBPM();
float getECG();
int getAirFlow();
int version();
uint8_t year;
uint8_t month;
uint8_t day;
uint8_t hour;
uint8_t minutes;
uint8_t glucose;
uint8_t meridian;
private:
int systolic;
int diastolic;
int BPM;
int SPO2;
uint8_t bodyPos;
byte data[6];
int accelCount[3];
float accel[3];
uint8_t length;
#endif
any help please and thanks
