eight LEDs flash only when I press the 74HC595 shift register
Hello,
The eight LEDs flash only when I press my thumb on the 74HC595 shift register. I shouldn't have to touch the components after uploading the code, so I need assistance. The video is attached.
Any help is appreciated :smiley:
No link to a video is seen (youtube fore example).
Do you have MR and OE/ connected? (MR to +5, OE/ to Gnd)
Welcome.
Show us a good schematic of your circuit.
Show us a good image of your ‘actual’ wiring.
Give links to components.
Posting images:
https://forum.arduino.cc/index.php?topic=519037.0
Use CTRL T to format your code.
Attach your ‘complete’ sketch between code tags, use the </> icon in the posting menu.
[code]Paste your sketch here[/code]
That is because your solderless bread board that I guess you are using is not very good and not actually making contact to all the pins of the chip. Try moving the circuit to use another set of pins or get another piece of solderless bread board.
Better yet, use strip board and an IC socket to solder up your circuit.
