Ein Beispiel für Timer / millis
Ich bin ein Anfänger in der Arduino Welt,
könnte sein das jemand mein Beispiel gebrauchen kann.
Würde mich über Verbesserungsvorschläge freuen.
benutzen:
struct DELAY MyTimer1 = run(ON TIME, OFF TIME);
Beispiel 1
TIMER 1 / ON 10 sec / OFF 2 sec
int count0 = 0;
int count1 = 0;
struct DELAY                  // Datentyp für DELAY
  unsigned long previousMillis;
  unsigned long intervalOn;
  unsigned long intervalOff;
  bool TRIGGER;
  Serial.println("Serial initialized!");
  struct DELAY MyTimer1 = run(10000, 2000);  // SET TIMER 1 /  ON 10 sec / OFF 2 sec
  count0 += 1;
  Serial.print(MyTimer1.TRIGGER ? ">> MyTimer1: ON  : " : "<< MyTimer1: OFF :");
  Serial.println(count0);
struct DELAY run(long _on, long _off)     //Funktion
  struct DELAY MyTIMER;
  MyTIMER.intervalOn = _on;
  MyTIMER.intervalOff = _off;
  if (MyTIMER.TRIGGER == HIGH && currentMillis - MyTIMER.previousMillis > MyTIMER.intervalOn) // ON
    MyTIMER.previousMillis = currentMillis;
    MyTIMER.TRIGGER = LOW;
  if (MyTIMER.TRIGGER == LOW && currentMillis - MyTIMER.previousMillis > MyTIMER.intervalOff) // OFF
    MyTIMER.TRIGGER = HIGH;
  return MyTIMER;
Beispiel 2
TIMER 2 / ON 5 sec / OFF 3 sec
TIMER 3 / ON 15 sec / OFF 15 sec
int count0 = 0;
int count1 = 0;
int count2 = 0;
int count3 = 0;
int count4 = 0;
int count5 = 0;
bool STATE1 = false;
bool STATE2 = false;
bool STATE3 = false;
  bool TRIGGER;
  struct DELAY MyTimer1 = run(10000, 2000), // SET TIMER 1 /  ON 10 sec / OFF 2 sec
         MyTimer2 = run(5000, 3000),  // SET TIMER 2 /  ON 5 sec / OFF 3 sec
         MyTimer3 = run(15000, 15000);  // SET TIMER 3 /  ON 15 sec / OFF 15 sec
  if (MyTimer1.TRIGGER != STATE1)
    if (MyTimer1.TRIGGER == HIGH)
      count0 += 1;
      Serial.print(">> MyTimer1: ON  : ");
      count1 += 1;
      Serial.print("<< MyTimer1: OFF : ");
      Serial.println(count1);
  STATE1 = MyTimer1.TRIGGER;
  if (MyTimer2.TRIGGER != STATE2)
    if (MyTimer2.TRIGGER == HIGH)
      count2 += 1;
      Serial.print(">> MyTimer2: ON  : ");
      Serial.println(count2);
      count3 += 1;
      Serial.print("<< MyTimer2: OFF : ");
      Serial.println(count3);
  STATE2 = MyTimer2.TRIGGER;
  if (MyTimer3.TRIGGER != STATE3)
    if (MyTimer3.TRIGGER == HIGH)
      count4 += 1;
      Serial.print(">> MyTimer3: ON  : ");
      Serial.println(count4);
      count5 += 1;
      Serial.print("<< MyTimer3: OFF : ");
      Serial.println(count5);
  STATE3 = MyTimer3.TRIGGER;
  return MyTIMER;
Mach eine richtige Klasse draus mit run() Methode in der Klasse. Statt ein Objekt mit den Daten außen herumzureichen
Und Namen in nur Großbuchstaben verwendet man normaler nur für Konstanten
