I have a JQC-3FF-S-Z relay module which I use to switch 110VAC EL(electroluminescent) wires (powered by 3VDC to 110VAC driver).
EL wires usually blink 2 times a second with certain pauses controlled by Arduino UNO.
The problem is that sometimes when the pause appears and the relay disconnects EL wires, they still keep blinking at the same pace for a short amount of time (2-3 secs).
couka:
Did you try connecting the relais in a way that shorts the el-wire when off instead of just "floating"?
Edit: Oops... I NC (2) and NO (3) should be the other way around... anyways, do you understand what I mean?
Thanks couka, that change did solve my issue.
Unfortunately, another problem showed up:
The driver actually has momentary push-button that controls three power modes (constant power + two blink variantions). I only needed constant power for this project, so I used a duct tape to tape the button down in place so its always pushed.
And now, from time to time, the driver runs into another power mode all by itself. It happens just after the relay switch.
The question is: can the relay switch cause this issue? Or is it a sign of driver overheat? And how do I check if so?
