elctric water valve control
for a electric water valve control (24vdc On/Off), I need a latching type relay setup controlled by arduino
the inbuilt valve control has 2 limit switches to cut of once they reached open or close positions.
any help is much appreciated.
Post a data sheet for the valve. Your assumption that we know all about the valve that you have is flawed.
Read the how to use this forum-please read sticky for some advice on what we need to know to help you.
achalaamarasinghe:
valve actuators are typically either power to open, then power to close
or they are power to open, spring close. power needed to hold in position
or they have a linear movement proportional to the signal
assuming that the valve takes 24VDC,
you can feed it 24VDC on 1 wire and ground the other wire
if the valve has 3 wires, it might be 24v on one wire to open
24v on a different wire to close
the other wire is common,
of course it might be that +24v on one and ground on the second (of 2) opens
ground on the first and +24v on the second to close.
if the internal end switches are accessible
you could use a common relay to open, once the end switch is closed, you remove the signal
alas, this all depends on the valve motor.
thanks for the reply ! forget about the valve side. are there any double pole latching type relays that can be controlled by arduino? from there i can work things out for my project.
thanks in advance
“I need a latching type relay setup controlled by arduino“
Is the relay a ‘latching relay’ with the mechanical latching mechanism built within.
OR
You want the Arduino to turn a DPDT ‘non latching’ relay into effectively a latching relay?
Hi. Go and check my Instructable at:
I guess that would be a smooth solution to your problem.
I have u bunch of these PCB's left ower, (you see, I needed only 2, but the manuf. delieveres them in a bunch of 10pcs).
My e-mail is: kimmo.selin@pp.inet.fi and web is: www.teksel.net
Please post me on this forum if you got help on this agenda?
achalaamarasinghe:
.are there any double pole latching type relays that can be controlled by arduino?
yes
yes i need a mechanical duble pole latching relay (state change with a pulse)
We need your relay requirement, but here is a 5v version:
Thanks ! i may have found one too
https://www.aliexpress.com/item/COM05061P-Grove-2-Coil-Latching-Relay-module/32532021916.html?spm=a2g0o.cart.99999999.265.737b3c001x9zSa
