Elechouse PN532 NFC module not being recognized by Arduino
Hey there. I’ve been reading this forum but I never registered to it until today. I just got the Elechouse PN532 NFC module from amazon and I can’t get it to work. I downloaded the library from Elechouse’s site but when I load it to the Arduino Uno I only get this:
MF1S50 Reader Demo From Elechouse!
Didn’t find PN53x board
I printed the versiondata and it returns a zero. I’ve already checked the connections, tried it in a Mega and I still get the message from above. I’ve also searched the same problem on the internet but I can’t still get a solution for my problem.
Please help, I’m working on a project and I really need this to get work.
Thanks :slight_smile:
//This example reads all MIFARE memory block from 0x00 to 0x63.
//It is tested with a new MIFARE 1K cards. Uses default keys for authenication.
//Contributed by Seeed Technology Inc (www.seeedstudio.com)
#include <PN532.h>
#include <SPI.h>
/*Chip select pin can be connected to D10 or D9 which is hareware optional*/
/*if you the version of NFC Shield from SeeedStudio is v2.0.*/
#define PN532_CS 10
PN532 nfc(PN532_CS);
#define  NFC_DEMO_DEBUG 1
void setup(void) {
#ifdef NFC_DEMO_DEBUG
  Serial.println("Hello!");
#endif
  nfc.begin();
  uint32_t versiondata = nfc.getFirmwareVersion();
  if (! versiondata) {
    Serial.print("Didn't find PN53x board");
#endif
    while (1); // halt
  // Got ok data, print it out!
  Serial.print("Found chip PN5");
  Serial.println((versiondata>>24) & 0xFF, HEX);
  Serial.print("Firmware ver. ");
  Serial.print((versiondata>>16) & 0xFF, DEC);
  Serial.print('.');
  Serial.println((versiondata>>8) & 0xFF, DEC);
  Serial.print("Supports ");
  Serial.println(versiondata & 0xFF, HEX);
#endif
  // configure board to read RFID tags and cards
  nfc.SAMConfig();
void loop(void) {
  uint32_t id;
  // look for MiFare type cards
  id = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A);
  if (id != 0)
    Serial.print("Read card #");
    Serial.println(id);
int x;
x = id;
Serial.print("New card id # is");
Serial.println(x);
if (id = -10794)
  Serial.print("Good Morning John");
#endif
    uint8_t keys[]= { 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF };// default key of a fresh card
    for(uint8_t blockn=0;blockn<64;blockn++)
      if(nfc.authenticateBlock(1, id ,blockn,KEY_A,keys)) //authenticate block blockn
        //if authentication successful
        uint8_t block[16];
        //read memory block blockn
        if(nfc.readMemoryBlock(1,blockn,block))
          //if read operation is successful
          for(uint8_t i=0;i<16;i++)
            //print memory block
            Serial.print(block[i],HEX);
            if(block[i] <= 0xF) //Data arrangement / beautify
              Serial.print("  ");
              Serial.print(" ");
          Serial.print("| Block ");
          if(blockn <= 9) //Data arrangement / beautify
            Serial.print(" ");
          Serial.print(blockn,DEC);
          Serial.print(" | ");
          if(blockn == 0)
            Serial.println("Manufacturer Block");
            if(((blockn + 1) % 4) == 0)
              Serial.println("Sector Trailer");
              Serial.println("Data Block");
#endif
  delay(2000);
I just noticed that the channels were in the wrong position. I'll upload a photo later of how it should be. Thanks anyways!
