ELECROW Christmas Sale: ESP32 Terminal & 4WD RC Smart Car Chassis for Arduino Up to 25% Off
Yo yearly Christmas event, check out what Elecrow has to offer in PCB, acrylic laser cutting, and 3D printing!
Regarding products, I'll highlight two Arduino-related products:
No.1:
This Elecrow ESP32 terminal is a microcontroller based on the ESP32 master. It adopts an Xtensa 32-bit LX7 dual-core processor with a main frequency of up to 240Mhz and supports 2.4GHz Wi-Fi and Bluetooth 5 (LE).
This ESP32 module also has a 3.5-inch parallel RGB interface capacitive touch screen with a resolution of 320*480 to ensure perfect image output at a frame rate (FPS) of 60. On the back of this terminal, we have introduced 4 Crowtail interfaces, which can be used with our Crowtail series sensors, plug and play, and create more interesting projects quickly and conveniently. In addition, it is also equipped with an SD card slot for extended storage (SPI leads) and a buzzer function. This ESP32 touchscreen supports ESP-IDF and Arduino IDE development and is compatible with Micropython/Arduino. It also supports LVGL , which is the most popular free and open-source embedded graphics library to create beautiful UIs for any MCU, MPU, and display type. Now it has also obtained the official certification of LVGL. LVGL's board certificate shows that the boards can be easily used with LVGL and have decent performance for UI applications. The onboard charging circuit and lithium battery interface can use the type-c power supply interface to supply power and charge the battery at the same time, providing more outdoor scene expansion possibilities.
No.2:
This is a newly designed 4-wheel car chassis, and ordinary 4-wheel drive is different from this car with rear-wheel drive plus a front steering mechanism to achieve the car forward, backward, and turn left and right.
Professional remote control racing principle, the use of two rods through the steering servo to control the direction of the car. In addition, the steering mechanism of the rear wheel has also been changed. The aluminum fixing piece is integrally formed with the motor and the motor is tightly engaged with the drive shaft. The motor adopts the all-metal gear motor. If you pursue high speed, As long as the 25mm shaft diameter motor can be. The rear wheel incorporates two flange cup bearings to ensure a more flexible motor rotation.
ELECROW helps you save money while preparing great gifts for your family and friends.
