Elecrow GPS Shield Data Logging Problem
Hi everyone,
I got this GPS shield: GPS shield - Elecrow
And I have Arduino Uno.
I want to save the GPS data to the SD card. I found this tutorial on the web: Tutorial 15 for Arduino: GPS Tracking – JeremyBlum.com
My GPS have these information in the datasheet. My shield's Rx pin is 7 and Tx pin is 6.
Baud-rate= 9600
SD chip select= 10
I made the corrections on the test code in the tinyGPS library and it worked perfect.
Here is the Serial Monitor screen caps: http://i.imgur.com/nB1CsfW.jpg?1
In the second part i do data logging. Again i did the corrections on Jeremy Blums code. But this time i can't even see the Char Rx column numbers are increasing. Here is my code:
#include <SoftwareSerial.h>
#include <TinyGPS.h>
#include <SD.h>
#include <stdlib.h>
/* This sample code demonstrates the normal use of a TinyGPS object.
   It requires the use of SoftwareSerial, and assumes that you have a
   9600-baud serial GPS device hooked up on pins 7(rx) and 6(tx).
TinyGPS gps;
static char dtostrfbuffer[20];
int CS = 10;
//Define String
String SD_date_time = "invalid";
String SD_lat = "invalid";
String SD_lon = "invalid";
String dataString ="";
SoftwareSerial nss(6, 7);
static void gpsdump(TinyGPS &gps);
static bool feedgps();
static void print_float(float val, float invalid, int len, int prec, int SD_val);
static void print_int(unsigned long val, unsigned long invalid, int len);
static void print_date(TinyGPS &gps);
static void print_str(const char *str, int len);
  pinMode(CS, OUTPUT);  //Chip Select Pin for the SD Card
  nss.begin(9600);
  //Connect to the SD Card
  if(!SD.begin(CS))
    Serial.println("Card Failure");
    return;
  Serial.print("Testing TinyGPS library v. "); Serial.println(TinyGPS::library_version());
  Serial.println("by Mikal Hart");
  Serial.print("Sizeof(gpsobject) = "); Serial.println(sizeof(TinyGPS));
  Serial.println("Sats HDOP Latitude Longitude Fix  Date       Time       Date Alt     Course Speed Card  Distance Course Card  Chars Sentences Checksum");
  Serial.println("          (deg)    (deg)     Age                        Age  (m)     --- from GPS ----  ---- to London  ----  RX    RX        Fail");
  Serial.println("--------------------------------------------------------------------------------------------------------------------------------------");
  bool newdata = false;
  unsigned long start = millis();
  // Every second we print an update
  while (millis() - start < 1000)
    if (feedgps())
      newdata = true;
  gpsdump(gps);
  //Write the newest information to the SD Card
  dataString = SD_date_time + "," + SD_lat + "," + SD_lon;
  //Open the Data CSV File
  File dataFile = SD.open("LOG.csv", FILE_WRITE);
  if (dataFile)
    dataFile.println(dataString);
    Serial.println(dataString);
    dataFile.close();
    Serial.println("\nCouldn't open the log file!");
  float flat, flon;
  unsigned long age, date, time, chars = 0;
  unsigned short sentences = 0, failed = 0;
  static const float LONDON_LAT = 51.508131, LONDON_LON = -0.128002;
  print_int(gps.satellites(), TinyGPS::GPS_INVALID_SATELLITES, 5);
  print_int(gps.hdop(), TinyGPS::GPS_INVALID_HDOP, 5);
  gps.f_get_position(&flat, &flon, &age);
  print_float(flat, TinyGPS::GPS_INVALID_F_ANGLE, 9, 5, 1);
  print_float(flon, TinyGPS::GPS_INVALID_F_ANGLE, 10, 5, 2);
  print_int(age, TinyGPS::GPS_INVALID_AGE, 5);
  print_date(gps);
  print_float(gps.f_altitude(), TinyGPS::GPS_INVALID_F_ALTITUDE, 8, 2, 0);
  print_float(gps.f_course(), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2, 0);
  print_float(gps.f_speed_kmph(), TinyGPS::GPS_INVALID_F_SPEED, 6, 2, 0);
  print_str(gps.f_course() == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(gps.f_course()), 6);
  print_int(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0UL : (unsigned long)TinyGPS::distance_between(flat, flon, LONDON_LAT, LONDON_LON) / 1000, 0xFFFFFFFF, 9);
  print_float(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : TinyGPS::course_to(flat, flon, 51.508131, -0.128002), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2, 0);
  print_str(flat == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(TinyGPS::course_to(flat, flon, LONDON_LAT, LONDON_LON)), 6);
  gps.stats(&chars, &sentences, &failed);
  print_int(chars, 0xFFFFFFFF, 6);
  print_int(sentences, 0xFFFFFFFF, 10);
  print_int(failed, 0xFFFFFFFF, 9);
  char sz[32];
  if (val == invalid)
    strcpy(sz, "*******");
    sprintf(sz, "%ld", val);
  sz[len] = 0;
  for (int i=strlen(sz); i<len; ++i)
    sz[i] = ' ';
  if (len > 0)
    sz[len-1] = ' ';
  Serial.print(sz);
  feedgps();
  char sz[32];
  if (val == invalid)
    sz[len] = 0;
        if (len > 0)
          sz[len-1] = ' ';
    for (int i=7; i<len; ++i)
        sz[i] = ' ';
    Serial.print(sz);
    if(SD_val == 1) SD_lat = sz;
    else if(SD_val == 2) SD_lon = sz;
    Serial.print(val, prec);
    if (SD_val == 1) SD_lat = dtostrf(val,10,5,dtostrfbuffer);
    else if (SD_val == 2) SD_lon = dtostrf(val,10,5,dtostrfbuffer);
    int vi = abs((int)val);
    int flen = prec + (val < 0.0 ? 2 : 1);
    flen += vi >= 1000 ? 4 : vi >= 100 ? 3 : vi >= 10 ? 2 : 1;
    for (int i=flen; i<len; ++i)
      Serial.print(" ");
  feedgps();
  int year;
  byte month, day, hour, minute, second, hundredths;
  unsigned long age;
  gps.crack_datetime(&year, &month, &day, &hour, &minute, &second, &hundredths, &age);
  if (age == TinyGPS::GPS_INVALID_AGE)
    Serial.print("*******    *******    ");
    char sz[32];
    sprintf(sz, "%02d/%02d/%02d %02d:%02d:%02d   ",
        month, day, year, hour, minute, second);
    Serial.print(sz);
    SD_date_time = sz;
  feedgps();
  int slen = strlen(str);
  for (int i=0; i<len; ++i)
    Serial.print(i<slen ? str[i] : ' ');
  feedgps();
  while (nss.available())
    if (gps.encode(nss.read()))
      return true;
  return false;
Here is the Serial Monitor caps which I got: http://i.imgur.com/RBj9Wbf.jpg?
And what it should be like: http://i.imgur.com/WUf54NR.jpg?1
I am trying to fix this for days. I searched on Google. Still I can not get to anywhere. :slightly_frowning_face:
If you help I'll appreciate that.
Thanks in advance. Sorry for my language.
That's hardly my definition of "works perfectiy". You are printing data you didn't read.
The second image shows that the Arduino is resetting. That's either a memory problem or a hardware problem.
Here's a start to figuring out which it is: Arduino Playground - HomePage
Not in my universe.
