elecrow wifi shield not connecting
I am trying to connect the elecrow wifi shield (uses an RN-171 chip) to the wifi, I’ve entered the relevant information (wifi name&password, ip address) and for some reason it still won’t connect
the message I recieve when running the program is:
Connect to 172.20.5.240:90
<4.41> ERR:NOIP
exit
exi
EXIT$$)þCMDopen 172.20.5.240 90
)öý•ÿþ17¹þ20.5.240åÿ0
<4.41> ERR:NOIP
exit
Kÿt
)öý•ÿþ17¹þ20.5£þ0åÿ0
at which point it will take a few seconds and then give the same message again.
does anyone have any ideas?
Which program would that be?
Looks to me like you have a baud rate mismatch somewhere.
the profram I’m using is the example program from elecrow’s website
#include "Wifly.h"
#include <SoftwareSerial.h>
WiflyClass Wifly(2,3);
  Serial.begin(9600);//use the hardware serial to communicate with the PC
  Wifly.init();//Initialize the wifishield
  Wifly.setConfig("WIFISCHOOL22","accessschool");//here to set the ssid and password of the Router
  Wifly.join("WIFISCHOOL22");
  Wifly.checkAssociated();
  while(!Wifly.connect("172.20.5.240","90"));//connect the remote service
  Wifly.writeToSocket("Connected!");
  if(Wifly.canReadFromSocket())
    Serial.print(Wifly.readFromSocket());
  if(Serial.available())
    Wifly.print((char)Serial.read());
if it is a mismatched baud rate, would you have any idea how to fix it maybe?
Does your school network permit connections on port 90?
Not a clue. I don't have that library or that hardware.
