electret microphone
my microphone gives an output as
843
842
842
842
842
843
843
843
843
843
843
843
843
845
843
842
843
843
842
841
under normal conditions without opamp.... and when i clapped "very near" to microphone,then its output is about 800-840.... so that i m able to blink an led accordingly...........
it works well.... but i want to increase its range of sound detection......and how to read readings from opamp,and what type of value it gives??
plzz help
The circuit at the end of the first page of this datasheet looks like what you need. It has a gain of 100 and should be a definite improvement! - a low-voltage rail-to-rail opamp such as the one in the datasheet is advised for 5V operation: http://www.stanford.edu/class/ee133/datasheets/LT1677.pdf
Linked from the Arduino Playground http://www.dtic.upf.edu/~jlozano/interfaces/microphone.html
how to give pin4 a -1.5v. and what type of reading this amplifier gives to arduino, digital or analog?...and how to analyze that... is it possible with LM358 op-amp??
