Electric/electronic problem arduino-relays-AC_motor
Hello, i have created a window blind/cover control for arduino, all fine... until the 300W motor comes into scene.
Problem: the arduino resets REALLY OFTEN when motor starts. Or immediately at relay activation, but ONLY when motor is connected.
The schema is simple:
-2 relay TTL module https://es.aliexpress.com/item/33050594625.html?spm=a2g0s.9042311.0.0.34d663c0IVo8Q3
-Arduino pro mini 3.3v
-RA-02 antenna
-Power supply: Diymore Módulo transformador AC 110V 220V a DC 5V 700mA, convertidor reductor de AC DC, placa de fuente de alimentación|buck converter|ac-dc 5vdc dc 5v - AliExpress
-Cables:
1.5mm for 220v power
0.15 jumper/cables internal circuit
220v to:
-Motor
-Power supply
-Relays
5v to:
-Arduino pro RAW
-Relays power
Arduino 3.3v internal used for RA-02
Pls hLp :cry: :cry:
It sounds like you have interference from the motor at startup.
Does the problem persists if you power the arduino from a battery instead from the PSU?
I would also suggest good metal shielding of the arduino with solid ground.
Can you post a picture of your project so we can see your component layout?
Have you got the 230Vac wiring away fro the controller and low voltage wiring?
Solved using different power supply.
The posted before output was like this:
Google Photos
0.2V default ripple, and vcc shakes when engine starts.
I just finally used a phone charger circuit.
Thsnka 4 all anyway
