Hello Everyone,
Very new to the Arduino community. I've been laying the ground work for developing an electric skateboard and after research and consideration, I would like to use an arduino uno + HC-05 bluetooth module + a "universal" bluetooth game controller to control the ESC that controls the brushless motor and drives the skateboard. People that use the arduino uno as a tx/rx board typically use a wireless Wii nunchuck or an app. The Wii nunchuck is a bit more pricey than just buying a universal bluetooth controller. To save a few extra bucks on the project, I was wondering if the coding for a universal bluetooth controller would be significantly different than the coding for the Wii nunchuck?
Code for Wii nunchuck (credit to Rahul Iyer for the code):
- Rahul Iyer
#include <Servo.h>
#include <Wire.h>
#include <ArduinoNunchuk.h>
#define BAUDRATE 19200
#define CHUCK_ZERO 133
#define CHUCK_MAX 255
#define ESC_ZERO 90
#define SPEED_MAX 130
ArduinoNunchuk nunchuk = ArduinoNunchuk();
int escOutputValue = ESC_ZERO;
float currentOutputValue = ESC_ZERO;
int resetCounter = 0;
Servo ESC;
ESC.attach(9);
Serial.begin(BAUDRATE);
nunchuk.init();
delay(100);
resetCounter++;
if (resetCounter==40)
resetCounter=0;
nunchuk.init();
delay(100);
nunchuk.update();
// Serial.print(nunchuk.analogX, DEC);
// Serial.print(' ');
// Serial.print(nunchuk.analogY, DEC);
// Serial.print(nunchuk.accelX, DEC);
// Serial.print(nunchuk.accelY, DEC);
// Serial.print(nunchuk.accelZ, DEC);
// Serial.print(nunchuk.zButton, DEC);
// Serial.print(nunchuk.cButton, DEC);
int yValue = nunchuk.analogY;
if (yValue<CHUCK_ZERO)
yValue = CHUCK_ZERO; // no backwards
// escOutputValue = map(yValue, CHUCK_ZERO, CHUCK_MAX, ESC_ZERO, SPEED_MAX); //linear relationship between joystick value and ESC output value--deemed not good enough
if (yValue == CHUCK_ZERO)
escOutputValue = ESC_ZERO; //if joystick is at zero, no power to motor (coast)
currentOutputValue = ESC_ZERO; //reset
int maxPossibleSpeed = map (yValue, CHUCK_ZERO, CHUCK_MAX, ESC_ZERO, SPEED_MAX);
if (escOutputValue > maxPossibleSpeed)
escOutputValue = maxPossibleSpeed;
float increment = (1.0 * (yValue - CHUCK_ZERO)) / (CHUCK_MAX - CHUCK_ZERO);
currentOutputValue += increment;
escOutputValue = (int) currentOutputValue;
ESC.write(escOutputValue);
Serial.println(escOutputValue); //for debugging
Also, would the wiring be the same (Please see attachment for diagram)?
