Electrical discharge in USB port
Hello everyone,
Recently, I got a generic Ethernet shield for my arduino Uno.
The shield - as you know- comes with a Wiznet W5100 whose tends to heat in normal use; However, I realized that it was too hot -in my opinion- , so I started to look for answers and I noticed that the laptop charger that I was using had only 2 prong so I tried with a 3 prong and it seemed to get the Wiznet a little bit cooler...
However, while I was doing experiments, my left cheek touched the arduino´s usb port ( the one next to reset button) and I felt a small electrical discharge, then I thought of using a 3 prong charger and the discharge disappear.
I have 2 questions:
  1. ¿Do you guys think that the electrical and heat problem was because of a lack of ground?
  2. Due to the fact that sometimes I do not have a pc at hand to power the arduino, ¿ could I use an Iphone 5 charger (output 5V & 1 A)?
I´m concern about amps cuz I have heard that what´s important in chargers is the voltage and that I the charger gives you more amps that the load needs it does not matter because the load will use only the amps needed...
Any thoughts ?
Thanks in advance,
:grin:
This could be one of two things:
Capacitive leakage from the switch-mode supply causing a small AC current which you can feel - not unknown and is a consequence of unpolarised 2 wire mains connectors on the switch-mode input. You can try reversing the 2-pin plug.
Or it could be a faulty and dangerous unit.
Using 3-pin plug would be advisable I reckon.
The temperature of the Wiznet chip is a red-herring, it will be hot it takes something like 150mA as its driving ethernet which is power hungry. Check the USB 5V rail with a multimeter if you like.
03ed: The shield - as you know- comes with a Wiznet W5100 whose tends to heat in normal use; However, I realized that it was too hot -in my opinion- , so I started to look for answers and I noticed that the laptop charger that I was using had only 2 prong so I tried with a 3 prong and it seemed to get the Wiznet a little bit cooler...
Did you measure it with a thermometer? I think the "cooling" was probably in your imagination.
03ed: 1. ¿Do you guys think that the heat problem was because of a lack of ground?
No.
03ed: 2. Due to the fact that sometimes I do not have a pc at hand to power the arduino, ¿ could I use an Iphone 5 charger (output 5V & 1 A)?
Yes.
03ed: I have heard that what´s important in chargers is the voltage and that I the charger gives you more amps that the load needs it does not matter because the load will use only the amps needed...
Correct.
03ed: Any thoughts ?
If it's keeping you awake, get one of these: http://www.ebay.com/itm/221461661634
