Electrical Setup for Servos with Arduino
Hello all,
I have about seven servos that I want to connect to a breadboard that is powered. But I don't know what to buy to power this or whether it should be batteries or a wall port. I do plan on powering the arduino and breadboard separate I don't want to kill it. I have five TowerPro MG996R Servos, and two LewanSoul LDX-227 running parallel.
I have looked up the specs of these and the Towerpro have a operating voltage of 4.8-7.2 V and a running current of 500mA-900mA. The LewanSoul had a operating voltage of 7.4 V and a working current of 1 A.
Thanks in advance.
hmmm....
One has a range of 4.8-7.2
The other is 7.4
What voltage are you planning to run?
Be aware that breadboards are good at carrying signal-level currents.
They are less good at carrying motor-level currents, especially when using multiple motors in parallel.
When I was running many servos, I used the breadboard for proof of concept then soldered up better pieces for carrying that much current.
Batteries are easy. But either way, make sure you have a common ground.
The servo power supply needs to be able to provide 1 Ampere per servo. The starting current is much higher than the running current.
Obviously, you can't run 7.4 and 5 V servos from the same power supply.
I agree with the above, do not use the breadboard to distribute servo power, as that will burn the tracks.
vinceherman:
hmmm....
The other is 7.4
What should we be getting if were not connecting the power to the breadboard?
Connect the servo power and ground to a suitable battery pack or power supply with wires, using high quality connectors, or solder the connections. Connect all the grounds.
jremington:
So do you have any suggestions of what to use?
On one project with multiple servos, I used a 3 row male header.
I soldered a wire across all the grounds and soldered the ground from the power supply to that (with a lead to the arduino for common grounds)
I soldered a wire across all of the power and soldered the 6v from my supply to that. You can use whatever voltage level your servos support.
I soldered a lead from each signal pin and plugged the other end in to the appropriate pin on my arduino.
Then I plugged all the servos in to the header.
