Electricity Project
I'm in a physics class and would like to go above and beyond, but i need some help getting this code to work. Any suggestions? Code is below all help is appreciated. Basically what i wanted to do is control lights on and off with a pushbutton using my own code, but it is not registering and nothing is lighting up. I also have a potentiometer that will control the brightness of the PWM leds, the pot is working just not the digital pins. There are 5 buttons and 7 LEDs.
Thanks,
Andrew
#define led1 0
#define led2 1
#define led3 2
#define led4 3
#define led5 4
#define led6 5
#define led7 6
#define button1 7
#define button2 8
#define button3 9
#define button4 10
#define button5 11
int state1 = 0; //stores the current state of the led
int state2 = 0;
int state3 = 0;
int state4 = 0;
int state5 = 0;
int pot = 0;
int potval = 0;
int temp1 = 0;
int temp2 = 0;
int temp3 = 0;
int temp4 = 0;
int temp5 = 0;
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
  pinMode(led3, OUTPUT);
  pinMode(led4, OUTPUT);
  pinMode(led5, OUTPUT);
  pinMode(led6, OUTPUT);
  pinMode(led7, OUTPUT);
  pinMode(button1, INPUT);
  pinMode(button2, INPUT);
  pinMode(button3, INPUT);
  pinMode(button4, INPUT);
  pinMode(button5, INPUT);
  Serial.begin(9600);  //for debugging
  pot = analogRead(0); //get reading from pot
  potval = map(pot, 0, 1023, 0, 255); //if it appears that the whole scale is not used use a smaller or no resistor
  if(button1==1 || button2==1 || button3==1 || button4==1 || button5==1)  // if any state change wait 50ms for debounce
    delay(50);  //debounce
    temp1 = digitalRead(button1);  //then determine which buttons were pressed
    temp2 = digitalRead(button2);
    temp3 = digitalRead(button3);
    temp4 = digitalRead(button4);
    temp5 = digitalRead(button5);
    if(temp1 == 1 && state1 == 0)        //if a button is pressed change the led status, if 0 change to 1, if 1 change to 0.
      state1 = 1;
      state1 = 0;
    if(temp2 == 1 && state2 == 0)
      state2 = 1;
      state2 = 0;
    if(temp3 == 1 && state3 == 0)
      state3 = 1;
      state3 = 0;
    if(temp4 == 1 && state4 == 0)
      state4 = 1;
      state4 = 0;
    if(temp5 == 1 && state5 == 0)
      state5 = 1;
      state5 = 0;
  if(state3 == 1 )  //change the status of the PWM LEDs
    analogWrite(led4, potval);
    analogWrite(led4, 0); //write the pot value or off
  if(state5 == 1 )
    analogWrite(led6, potval);//same as above
    analogWrite(led6, 0);
    digitalWrite(led1, state1);  //write status to digital leds
    digitalWrite(led2, state2);
    digitalWrite(led3, state3);
    digitalWrite(led5, state5);
    digitalWrite(led7, state5); //control 2 LEDs
    Serial.print(state1);  //to help with debugging, tell the state
    Serial.print("   ");
    Serial.print(temp1);
    Serial.print("   ");
    Serial.println(potval);
    delay(20);  //slow down the serial conn.
No code posted!
Code can't get more virtual than this.
I'd suggest instead of:
      state1 = 1;
      state1 = 0;
use
if(temp1)
      state1 = ~state1;
http://www.arduino.cc/playground/Code/BitMath
I'd also suggest http://arduino.cc/en/Reference/Array for your reading pleasure.
Given that:
#define button1 7
#define button2 8
#define button3 9
#define button4 10
#define button5 11
this:if(button1==1 || button2==1 || button3==1 || button4==1 || button5==1) doesn't ever seem likely, does it?
Also, not such a good idea to hang LEDs on a serial port you're trying to use for debugging.
Some guidance: start simple, and build up from that, testing and retesting at every stage.
Don't forget that you can use the analog pins as digital pins, too (A0, A1, A2, etc.).
Thanks for the tips guys! I am learning so much lately now that I've given more time to do what i love! The small things like code efficiency which i still don't fully understand! But, In reply to AWVOL's comment, i think that you have confused the operands because the if statement says if button1 OR button2 OR... is pressed DO... , so if any button is pressed!
-feel free to correct me if i'm wrong!
Thanks guys! oh, and I agree with you on the serial port thing, im short on pins and it was just occansionly used for debugging, when it is on display i will comment out.
Andrew
I think that I have been doing this sort of thing long enough that I am not confused.
I do however, despite my advancing years, remember how the C preprocessor works.
Let's expand the line causing the confusion, and see what the compiler sees:if(7==1 || 8==1 || 9==1 || 10==1 || 11==1)
All perfectly valid C, but a condition that is very unlikely to ever fire.
im short on pins
Did you read PaulS' comments about using the analogue pins as digital I/Os?
To expand on what AWOL is saying, your code is NOT saying that "if button1 is pressed OR button 2 is pressed OR...". It is saying "If the pin number is 1 OR the other pin number is 1 OR ...".
You are checking the value of the pin number, not the state of the pin.
if(state1 == 1 || state2 == 1 ...
Using HIGH or LOW instead of 0 and 1 makes the code easier to understand, by the way. One need not remember what value represents HIGH or LOW.
