electronic brick of microphone
GOOD MORNING
I have the sensor electronic brick of microphone.
I could connect him with arduino uno and counting noise??
I would also like to store in eeprom of arduino
it is possible??
This is link from sensor..
http://imall.iteadstudio.com/im120710013.html
This appears to be no more than a microphone.
We need more information on what you want to do.
What do you mean by "counting noise"?
Weedpharma
It is an Electret microphone. No more.
I'm afraid u'll be disappointed. If you just sample the analog value, without amplification, the values will vary just a fraction of the 0..5V span.
I guess 100..200 times ampl. can give do it. Then next 'problem' To sample voice u need at least 2000 samples a second.. To fast to store in eeprom, then store in all available RAM. (1/2 sec recording time?)
The good part: You CAN use the mic to detect a clap/'bang'. The analogvalue u read will vary (a 'step or two') in loud noise.
In the documntationthere is this 'demo' code
FILE: DEMO_MIC.pde
PURPOSE: MIC test sketch for Arduino
Created by Stan Lee from Iteadstuduino
E-mail: Lizq@iteadstudio.com
DATE: 2013/4/20
const int ledPin =  13;      // the number of the LED pin
const int thresholdvalue=400; //The threshold to turn the led on
    pinMode(ledPin, OUTPUT);
 int sensorValue = analogRead(A0); //use A0 to read the electrical signal
 if(sensorValue>thresholdvalue)
 digitalWrite(ledPin,HIGH); //if the value read from A0 is larger than 400,then light the LED
 delay(200);
 digitalWrite(ledPin,LOW);
Electronic brick of microphone can be connected to the analog I / O port, when speaking to the microphone, the analog value will be changed. A recorder can be made by reading and saving the analog value.
