electronic gearing
Hi !
I would like to make with arduino electronic gearing .
On master motor would be mounted quadrature encoder ( 2500 cpr ex. )
and slave motor should follow master on specified ratio. Slave motor would be step or servo motor and controlled with STEP / DIR signal.
So , we have to read encoder signals
then reduce it with ratio. ( ex. i = 20 )
every step must be divided by 20 .
and then output quadratute signal to Step motor drive.
Step rate should be up to 200 kHZ .
Any ideas how to do that ?
Which motor can do that?
jremington:
Most step motor drives go up to 200k step pulse rates .
I suggest to do some reading. This generic plot of torque versus step rate is something to think about:
Good luck with your project!
200kHz at 200 steps per revolution gives a motor speed of 60,000RPM
Microsteps of course. This is for servomotors too, which in step/direction mode can use very small microsteps.
