Hello, I am trying to make an electronic load, but I got stuck at the clock, so basically I want the clock to only run when current is flowing, so I could see how long it took to discharge a battery for example. I tried to set the clock to 0 when there is no current flowing, but the problem is that when the battery will give 0 amps then the clock will reset, how could I fix that?
#include <Wire.h>
#include <TimeLib.h>
#include <DallasTemperature.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET -1
#define ONE_WIRE_BUS 12
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
float totalCharge;
float averageAmps;
float ampSeconds;
float ampHours;
float miliampHours;
float wattHours;
float capacity;
float low_volt;
float current;
float voltage;
float volt;
float curr;
float temp;
float msec;
float time1;
int sample;
int value;
int fanPin=3;
int freq=2000;
int voltPin=A3;
int currPin=A2;
int powerPin=11;
int buzzerPin=2;
int button1_state;
int buttonPin1=5;
int button2_state;
int buttonPin2=6;
int button3_state;
int buttonPin3=7;
int button4_state;
int buttonPin4=8;
int button5_state;
int buttonPin5=9;
int button6_state;
int buttonPin6=10;
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
pinMode(buttonPin1, INPUT);
pinMode(buttonPin2, INPUT);
pinMode(buttonPin3, INPUT);
pinMode(buttonPin4, INPUT);
pinMode(buttonPin5, INPUT);
pinMode(buttonPin6, INPUT);
pinMode(buzzerPin, OUTPUT);
pinMode(powerPin, OUTPUT);
pinMode(fanPin, OUTPUT);
pinMode(voltPin, INPUT);
pinMode(currPin, INPUT);
sensors.begin();
sensors.setResolution(9);
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
void printDigits(int digits){
display.print(":");
if(digits < 10)
display.print('0');
display.print(digits);
button1_state = digitalRead(buttonPin1);
button2_state = digitalRead(buttonPin2);
button3_state = digitalRead(buttonPin3);
button4_state = digitalRead(buttonPin4);
button5_state = digitalRead(buttonPin5);
button6_state = digitalRead(buttonPin6);
sensors.requestTemperatures();
temp = sensors.getTempCByIndex(0);
int oled =digitalRead(10);
if (temp>50)
digitalWrite(fanPin,HIGH);
if (temp<40)
digitalWrite(fanPin,LOW);
if (oled==0){
display.ssd1306_command(SSD1306_DISPLAYOFF);
display.ssd1306_command(SSD1306_DISPLAYON);
if(button1_state!=0){
low_volt = low_volt+0.1;
if(button2_state!=0){
low_volt = low_volt-0.1;
if(button3_state!=0){
low_volt = low_volt+1;
if(button4_state!=0){
low_volt = low_volt-1;
if(button5_state!=0){
digitalWrite(powerPin,LOW);
if(button6_state!=0){
digitalWrite(powerPin,HIGH);
if(low_volt>volt;value=0){
tone(buzzerPin,freq);
delay(100);
noTone(buzzerPin);
delay(100);
delay(100);
noTone(buzzerPin);
delay(100);
delay(100);
noTone(buzzerPin);
value = value+1;
if(curr==0){
setTime(0);
int v_sense = analogRead(voltPin);
float voltage = map(v_sense,0,1024,0,4720);
volt = voltage/125;
int c_sense = analogRead(currPin);
float current = map(c_sense,0,1024,0,4721);
curr = current/690*1.69;
float watts = volt*curr;
sample = sample + 1;
msec = millis();
time1 = msec / 1000.0;
totalCharge = totalCharge + curr;
averageAmps = totalCharge / sample;
ampSeconds = averageAmps*time1;
ampHours = ampSeconds/3600;
miliampHours = ampHours*1000;
display.clearDisplay();
display.setTextColor(WHITE);
display.setCursor(0,0);
display.print("Voltage: ");
display.print(volt);
display.println(" V");
display.print("Current: ");
display.print(curr);
display.println(" A");
display.print("Power: ");
display.print(watts);
display.println(" W");
display.print("Capacity:");
display.print(miliampHours);
display.println(" mAh");
display.print("Energy: ");
display.print(wattHours);
display.println(" Wh");
display.print("Low volt:");
display.print(low_volt);
display.print("Temp: ");
display.print(temp);
display.println(" C");
display.print("Time: 0");
display.print(hour());
printDigits(minute());
printDigits(second());
display.display();
delay(250);
