I want to create an electronic flute/ocarina type of instrument using an arduino. I am relatively new with arduino but I am not new to micro-controllers. I have a Bachelor's of Engineering in Electrical Engineering and decent soldering skills (but that wont come in until later) and I've decently familiar with C++ sans anything with a GUI. Right now I am trying to generate a shopping list of stuff I will need in order to prototype.
My biggest hurles are...
Breath pressure input. Is there an analog sensor that is able to measure breathing pressure which would determine the output volume.
-For my first prototype version I will probably go with a more digital approach and use a pressure sensor that would either trigger the sound to be on or off.
Finger input. I've seen multiple ways of going about finger inputs and I am unsure which one to go with. Force sensors, Capacitive touch...Push buttons. Another issue is accidental notes and sub holes which is not an immediate issue (I could sort of cheap and just make it so you can select a musical key)
Sound generation...This is probably my hardest issue. I am insure where to begin with this. Should I get a synth or a signal generator...I have absolutely no idea how I am going to generate a flute-ish sound.
Any insight you guys have would be wonderful.
If there is a post similar to this one I apolgoize. I checked and I didn't find any.
