Electrostatic Discharge/ ESD troubles with Wool + Arduino Unos + Ultrasonic Sensors
Hi all,
Here is a question related to Electrostatic Discharge, sensors, and wool (there is also some cotton, bamboo-polyester, and plastic) in an Arduino project
Let me preface this by saying I am new to electronics, Arduino, and this forum, so please forgive anything that needs forgiving in terms of wording, posting to the right place, etc.
I am using about 12 Arduino Uno’s in a large sculptural-felted installation project. I successfully soldered Adafruit “Music Maker” mp3 shields (link: Adafruit Music Maker MP3 Shield for Arduino w/3W Stereo Amp [v1.0] : ID 1788 : $34.95 : Adafruit Industries, Unique & fun DIY electronics and kits) to these devices, and hooked up ultrasonic sensors to them. With some coding assistance from a friend, the sensors can now trigger multiple mp3 files. All was running smoothly, until yesterday. We began to install these electronics into these large felted (made from wool) sculptures, and the sensors seem to be less accurate than before. Whats more, every time a piece of felted wool is put in front of the speaker-cone (where the sounds play from), it makes a fuzzy sound, like the wool is causing feedback (the sound stops after about 3 seconds if the wool is held there). Then I had that sinking feeling of a huge oversight: wool (and other fabrics)+ a dry environment +electronics = disaster????
Right now, the Arduinos are being housed in cheap plastic soap-boxes I purchased at the dollar store and cut the appropriate holes in for electronics.
My questions are:
  1. Am I in serious danger of frying all the Arduinos/ electronics just by keeping them inside of sculptures made of various insulating materials (mostly wool, bamboo-rayon, and polyester)?
  2. if so, how can I best protect the electronic components? Is there any value in trying to build faraday cages for each of them? Should I run the ground pin to something metal to discharge potential buildup? (For casing, I had originally looked at pre-fab plastic Arduino cases, but they are slightly too big to fit with the mp3 shields on them). Do I need a conductive cases? If this would be useful, is anyone aware of any slightly-oversized (bigger than an Arduino Uno) conductive boxes that can be used or modified to protect in-use Arduinos from ESD in high-charge environments?)
  3. Are the necessary holes in the Arduino casing (to run power and signal from) a potential entry point for ESD?
  4. Can ESD make its way through a speaker, up speaker wire, and fry to board that way?
  5. Any ideas why the speaker might be responding to the presence of wool?
  6. Lastly, I have also been running the power cord out with the sensor cables and speaker cables. Is this a problem? Do I need to run them perpendicular or separate (will running them alongside each other cause interference in this context)?
Any advice is greatly appreciated. Thanks in advance!
ESD is created when two different types of materials are rubbed together. One material will collect electrons from the other resulting in a voltage charge. Having low humidity helps make this collection create higher voltages.
For this to happen things have to be moving (not air moves) and can collect or proved electrons to another material. Look here for a list of materials and their propensity to create ESD.
ESD will go right through a speaker, unless the frame is grounded, then it will likely to right to ground.
Typically to protect from ESD one would physically place all wires going to a board in one location (i.e. bundle them). Then put a 0.1µF capacitor from each wire to the power supply common.
Are you SURE it is wool? Wool comes from sheep and is organic and very unlikely to be involved with static electricity. Besides static electricity takes TWO electrodes and energy from movement to remove or add electrons.
BET what you are calling "wool" is actually all or part synthetic fiber which will CERTAINLY be involved with static electricity generation.
Paul
My first thought here is to use an anti static fabric spray.
I have merged your cross-posts @earliest.
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting will result in a suspension from the forum.
In the future, please take some time to pick the forum category that best suits the subject of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide you will find at the top of every forum category. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Hey Paul. It is absolutely wool. We order it directly from a woman who shears the sheep herself, and then we felt it ourselves!
Thats a nice idea, thank you
Ok, The the next thing is the be sure every piece of metal in your device is connected to a common ground and that is connected to the AC power ground. That includes any speaker metal frames.
Thanks John. So this means that the wires from the sensor, the speaker wire, and the power cord can all be bundled? Does this mean wrapping them in something, or just tying them together?
There is only 1 power cable, does that change anything?
How are you powering the Arduinos? Through the 5V pin is the preferred way, if it is through the power jack you problem might just be overheating instead of static.
Powering through the power supply (with these: 9 VDC 1000mA regulated switching power adapter - UL listed : ID 63 : $8.95 : Adafruit Industries, Unique & fun DIY electronics and kits)
I think we need to power this way because there are no computers or breadboards involved in this design and we need them to be able to turn on and off with a light switch (they will plug into adaptors on track-lighting sockets)
Like I say this will get much hotter than it should as you are burning up that extra power as heat. This is more likely to be your problem.
You don’t have to power it that way if you get a 5V power supply and distribute it to all the 5V and ground pins on the Arduinos.
Forgive the noobie question, but do you mean a wall-adaptor 5v supply? I am having a hard time envisioning a 5v power supply that is not just an adaptor
Also, I thought that I needed slightly more power than that because there are amplifiers and such on the Adafruit Shield that is soldered to it?
Thank you!
From what you posted, is it correct to assume:
9 Volt adapter ---> Arduino uno power jack ----> through the UNO ---- > 5V to sensors
If so the Arduino is not designed to generate enough 5V power for many sensors and if your audio is also from the Arduino you are really in much worse shape.
You should do something like this:
Hey each Arduino has only 1 ultrasonic sensor.
And yes, it is
The amplifier and speaker input is on the Adafruit Music Maker mp3 shield, which is soldered to the arduino
Where does Adafruit Music Maker mp3 shield get its power?
The 9v power supply provides the power to both the Arduino and the shield
