Elegoo Auto Car Not Working
I bought and assembled (correctly, I think) the Elegoo Car Kit V3.
All connections seem to be correct and I got a successful code upload from PC to Car. The code is ‘Auto_Go’ code that came with the car. It simply moves the car in all four directions in a loop.
But I am not seeing the expected behaviour from the car. In this video, you can see the lights are ON: https://youtu.be/DsicMKhG0mU
What should I do now? Any help is appreciated.
Thanks!
(deleted)
Please post your full sketch. If possible you should always post code directly in the forum thread as text using code tags (</> button on the toolbar). This will make it easy for anyone to look at it, which will increase the likelihood of you getting help. If the sketch is longer than the forum will allow then it’s OK to add it as an attachment. If you click the “Reply” button, you’ll see an “Attachments and other options” link.
Thank you for the replies. Here is the Sketch:
//Car Movement Loop
//    The direction of the car's movement
//  ENA   ENB   IN1   IN2   IN3   IN4   Description
//  HIGH  HIGH  HIGH  LOW   LOW   HIGH  Car is runing forward
//  HIGH  HIGH  LOW   HIGH  HIGH  LOW   Car is runing back
//  HIGH  HIGH  LOW   HIGH  LOW   HIGH  Car is turning left
//  HIGH  HIGH  HIGH  LOW   HIGH  LOW   Car is turning right
//  HIGH  HIGH  LOW   LOW   LOW   LOW   Car is stoped
//  HIGH  HIGH  HIGH  HIGH  HIGH  HIGH  Car is stoped
//  LOW   LOW   N/A   N/A   N/A   N/A   Car is stoped
//define L298n module IO Pin
#define ENA 5
#define ENB 6
#define IN1 7
#define IN2 8
#define IN3 9
#define IN4 11
void forward(){
  digitalWrite(ENA,HIGH); //enable L298n A channel
  digitalWrite(ENB,HIGH); //enable L298n B channel
  digitalWrite(IN1,HIGH); //set IN1 hight level
  digitalWrite(IN2,LOW);  //set IN2 low level
  digitalWrite(IN3,LOW);  //set IN3 low level
  digitalWrite(IN4,HIGH); //set IN4 hight level
  Serial.println("Forward");//send message to serial monitor
void back(){
  digitalWrite(IN1,LOW);
  digitalWrite(IN2,HIGH);
  digitalWrite(IN3,HIGH);
  digitalWrite(IN4,LOW);
  Serial.println("Back");
void left(){
  Serial.println("Left");
void right(){
  Serial.println("Right");
//before execute loop() function,
//setup() function will execute first and only execute once
  Serial.begin(9600);//open serial and set the baudrate
  pinMode(IN1,OUTPUT);//before useing io pin, pin mode must be set first
  pinMode(IN2,OUTPUT);
  pinMode(IN3,OUTPUT);
  pinMode(IN4,OUTPUT);
  pinMode(ENA,OUTPUT);
  pinMode(ENB,OUTPUT);
//Repeat execution
  forward();  //go forward
  delay(1000);//delay 1000 ms
  back();     //go back
  left();     //turning left
  right();    //turning right
Here is my Upload Output:
vrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x_______(probably m328p)
avrdude: reading input file "C:\Users\AppData\Local\Temp\arduino_build_958504/AUTO_GO.ino.hex"
avrdude: writing flash (2296 bytes):
Writing | ################################################## | 100% 0.42s
avrdude: 2296 bytes of flash written
avrdude: verifying flash memory against C:\Users\AppData\Local\Temp\arduino_build_958504/AUTO_GO.ino.hex:
avrdude: load data flash data from input file C:\Users\AppData\Local\Temp\arduino_build_958504/AUTO_GO.ino.hex:
avrdude: input file C:\Users\AppData\Local\Temp\arduino_build_958504/AUTO_GO.ino.hex contains 2296 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.30s
avrdude: verifying ...
avrdude: 2296 bytes of flash verified
avrdude done. Thank you.
