Elegoo, lesson 9 Servo, Was working, then error, even when code reset to origin
Using the Elegoo ‘The Most Complete Starter Set’ and now stuck on lesson 9 ‘Servo’
This is the code
//www.elegoo.com
//2016.12.08
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 0;    // variable to store the servo position
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
    // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
The brown servo lead is connected to ground
the red servo lead to 5v
The orange signal lead on the servo to pin 9 pwm on an Elegoo Uno R3 board
Now first time I tried this it worked
Then I started to change the figures in the line
 [code]for (pos = 180; pos >= 0; pos -= 1
Changing the 1 to 10, 20, 45 and 90 to speed up the return twist.
But when I set it to 180 all I get is error
libraries\Servo\avr\Servo.cpp.o (symbol from plugin): In function ServoCount':** **(.text+0x0): multiple definition of ServoCount’
sketch\src\avr\Servo.cpp.o (symbol from plugin):(.text+0x0): first defined here
libraries\Servo\avr\Servo.cpp.o (symbol from plugin): In function ServoCount':** **(.text+0x0): multiple definition of __vector_11’
libraries\Servo\avr\Servo.cpp.o (symbol from plugin): In function ServoCount':** **(.text+0x0): multiple definition of Servo::Servo()'
libraries\Servo\avr\Servo.cpp.o (symbol from plugin): In function ServoCount':** **(.text+0x0): multiple definition of Servo::attach(int, int, int)'
libraries\Servo\avr\Servo.cpp.o (symbol from plugin): In function ServoCount':** **(.text+0x0): multiple definition of Servo::attach(int)'
libraries\Servo\avr\Servo.cpp.o (symbol from plugin): In function ServoCount':** **(.text+0x0): multiple definition of Servo::detach()'
libraries\Servo\avr\Servo.cpp.o (symbol from plugin): In function ServoCount':** **(.text+0x0): multiple definition of Servo::writeMicroseconds(int)'
libraries\Servo\avr\Servo.cpp.o (symbol from plugin): In function ServoCount':** **(.text+0x0): multiple definition of Servo::write(int)'
libraries\Servo\avr\Servo.cpp.o (symbol from plugin): In function ServoCount':** **(.text+0x0): multiple definition of Servo::readMicroseconds()'
libraries\Servo\avr\Servo.cpp.o (symbol from plugin): In function ServoCount':** **(.text+0x0): multiple definition of Servo::read()'
libraries\Servo\avr\Servo.cpp.o (symbol from plugin): In function ServoCount':** **(.text+0x0): multiple definition of Servo::attached()'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino/Genuino Uno.
I tried to go back to original numbers same error, but when I copied the original sketch code from the original zip file to revert the code in the folder I open it from to its factory setting code.
it is still not working so whats happening please?
Now when I tried this first time
[/code]
The problem has nothing to do with you setting it to 180. It seems like just a glitch in the Arduino IDE. Try restarting the Arduino. That will clear the compilation cache and hopefully solve the problem.
How exactly do I reset it?
I closed, quit and started the auduino software, then reset the computer and started it.
As said I replaced the code in the file with the original factory code for lesson 9, made sure the library was added as a zip file and still gettign errors.
//www.elegoo.com
//2016.12.08
#include <Servo.h>
ERRORS
Arduino: 1.8.5 (Windows 7), Board: “Arduino/Genuino Uno”
libraries\Servo\avr\Servo.cpp.o (symbol from plugin): In function `ServoCount’:
(.text+0x0): multiple definition of `ServoCount’
(.text+0x0): multiple definition of `__vector_11’
(.text+0x0): multiple definition of `Servo::Servo()’
(.text+0x0): multiple definition of `Servo::attach(int, int, int)’
(.text+0x0): multiple definition of `Servo::attach(int)’
(.text+0x0): multiple definition of `Servo::detach()’
(.text+0x0): multiple definition of `Servo::writeMicroseconds(int)’
(.text+0x0): multiple definition of `Servo::write(int)’
(.text+0x0): multiple definition of `Servo::readMicroseconds()’
(.text+0x0): multiple definition of `Servo::read()’
(.text+0x0): multiple definition of `Servo::attached()’
exit status 1
“Show verbose output during compilation”
option enabled in File → Preferences.
Before the servo stopped working was it getting hot?
That is all I can think of right now.
I have the same kit. If you tell the servo to go to 0 it buzzes. It gets hot.
Instead of going to 0 go to 15. More in line anyway.
