Hi
I'm new to Arduino. I'm building points for my model railway and the other day testing was fine. I have come to set up more servos today and have an issue with the hardware I think. Below are the error messages. When I used it last I'm sure the board selected was Adafruit Circuit Playground and usbmodem (USB) as the port. But this isn't working. I tried with Arduino Mega2650 selected, again via USB and still not working - Would appreciate any help. I'm using Macbook on Ventura OS. Thanks, Rik.
Sketch uses 11320 bytes (39%) of program storage space. Maximum is 28672 bytes.
Global variables use 618 bytes of dynamic memory.
Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
Found programmer: Id = ""; type =
Software Version = .; Hardware Version = .
avrdude: error: buffered memory access not supported. Maybe it isn't
a butterfly/AVR109 but a AVR910 device?
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: error: programmer did not respond to command: leave prog mode
avrdude: error: programmer did not respond to command: exit bootloader
Failed uploading: uploading error: exit status 1
